Results 1 to 10 of 14
Thread: VE Table MAP 30 row help
    Default VE Table MAP 30 row help
    Why is it no matter how many times I log the MAP 30kpa row logs rich. The following pics are the latest table and latest log file. Could it be the cam? 231/237 112lca.
    click for larger image
    [IMG][/IMG]
    [IMG][/IMG]
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Why are you using the back-up VE table? Have you eliminated the MAF sensor?
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Yes, I have. Both tables show rich like that though.
    Jan 2005
    The cam will have some effect especially under decel and at closed throttle. With the cam you have, I'd guess that's the only time your engine sees 20-30 kPa. What are actual wide band values at 30 kPa? What's manifold pressure and AFR at idle?
    678/344-1590
    She idles in the 50-60 range. I got it to idle at 1.0 EQ almost constantly. Question would be. What should I do with this area? Some of the values are as low as 16.
    Can anyone else chime in here?
    Jan 2005
    Ching!
    Safe to assume you are in the AutoVE process? Have you double checked that all steps in the tutorial were followed? Are you sure you don't have a hardware problem (vacuum leak, exhuast leak, fouled plug, etc...) Anything else you can tell us about it?
    Yes, I have check all steps and done them all. Plugs are new. Logged for missfires and found nothing other than 1 here or there. Not even enough to set an ses over time very minimal. Headers and collectors seem sealed up well and I cannot find a vacuum leak. When I log I due get off the gas a good bit which I noticed the 25-35 rows fall into alot while decelerating.
    IAC counts sit between 45-60 at idle. Whenever I do adjust the VE and the 30 row changes up so much the drivability goes away giving me bucking in this cell region. The more logging I do and then paste/mutiply, the worse the bucking gets and getting back on the throttle after leaving off gets worse each time.
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Filter out decel and that will give you a more accurate reading IMO. If you are under decel more then accel or vice versa, it can throw off your readings. Try to make the logs as consistent as possible to eliminate any other possibilities.
    I thought about that but am at a loss as to creating a filter to filter out decel.
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. OLFA table vs. Custom OS A0008 table
  3. Table Names vs Table Number
    By lplott in forum Custom Operating Systems
    Last Post: May 17th, 2006, 05:14 AM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
