Results 1 to 2 of 2
Thread: A50 garbled VIN
    Default A50 garbled VIN
    I have a bunch of A50 and T14 TCM's, presumably from working trucks or these were tossed as cores. Each one appears to have an LMM (...459) cal file or LML (...880) cal file, but each one has a garbled or nonsensical VIN when I check the status.
    1. Does anyone know if this is normal, or what may cause it?
    2. Does it indicate another problem with the TCM?
    Thanks for whatever contribution you can make. Times are TOUGH in the module world right now, especially A50/T14 modules. Thousands of unrepaired trucks are stacking up. I pulled these TCM's out of deep storage and trying to do something with them.
    Custom Tuning Services
    The VIN, along with other data that must remain permanently in the ECM when power is switched off is stored in the NVRAM (non volatile RAM) area of the flash memory.
    That memory is made up of two banks of flash memory, so that a backup copy can be maintained. The backup is needed in case power is removed while the ECM is erasing/updating the data. One bank will always contain valid data - even if the other one has been erased.
    EFILive makes an "educated" guess as to which bank contains the current/valid data. It could be that EFILive picked the wrong bank.
    If you read out a few of the TCMs and send me the tune files, I can convert them to bin files and can investigate the data in the NVRAM area to see if it is viable or not.
    Also send me a screen shot of the [F4: OBD] data for each TCM before you read it out.
    Send then to paul@efilive.com
  1. spark table numbers in hex or garbled
    By 58nate in forum FlashScan V3
    Last Post: October 11th, 2022, 04:36 PM
  2. VIN Won't Flash LS1B VIN 000
    By OrionATX in forum Gen III V8 Specific
    Last Post: December 18th, 2017, 02:58 PM
  3. A50 vin
    By Rthms20 in forum Allison 5 & 6 Speed
    Last Post: July 14th, 2017, 09:22 AM
  4. changing vin on lmm to my suburban vin. is this doable?
    By Madspeed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2015, 03:14 AM
  5. what vin do i use the ecm vin or the dash vin
    By nycblazer in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2008, 04:31 AM
