Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: 12592618 cax for 4l80e TCC unlock tables
    Sep 2012
    Default 12592618 cax for 4l80e TCC unlock tables
    I've got the above OS and updated the cax file to add the B9021 min injector pulse table. Now I'm trying to add the 4l80e TCC unlock tables to prevent the unlock at light load, but am getting some weird errors. I copied the below info from another member into my OS cax file but I get the error attached. I can't seem to upload a .cax file in my post to share. Can anyone tell me what I'm doing wrong?
    [D3001]
    ; Description
    DESC.001 = The Low Speed TPS threshold will be used if the VSS is below this value.
    DESC.002 =
    DESC.003 =
    ; Seg Caption Major Minor Vis Dis 2D Grp
    VIEW = 4 "Min throttle mode - Low speed" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1A006 0 16 SNM 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = MPH 3.90625E-03 0 0 0 256 0 256
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    [D3002]
    ; Description
    DESC.001 = The High Speed TPS threshold will be used if the VSS is above this value.
    DESC.002 =
    DESC.003 =
    VIEW = 4 "Min throttle mode - High speed" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ADDR = 1A008 0 16 SNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    [D3003]
    ; Description
    DESC.001 = Minimum Throttle Mode will enable if the TPS is below this value.
    DESC.002 =
    DESC.003 =
    VIEW = 4 "Low Speed Min Throttle TPS Low" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ADDR = 1A00A 0 16 UNM 0
    SI_SLOT = % 3.051758E-03 0 0 0 100 0 100
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    [D3004]
    ; Description
    DESC.001 = Minimum Throttle Mode will disable if the TPS is above this value.
    DESC.002 =
    DESC.003 =
    VIEW = 4 "Low Speed Min Throttle TPS High" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ADDR = 1A00c 0 16 UNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    [D3005]
    ; Description
    DESC.002 =
    DESC.003 =
    VIEW = 4 "High Speed Min Throttle TPS Low" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ADDR = 1A00E 0 16 UNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    [D3006]
    ; Description
    DESC.002 =
    DESC.003 =
    VIEW = 4 "High Speed Min Throttle TPS High" "TCC" "Min Throttle TCC Release" 1 1 0 0
    ADDR = 1A010 0 16 UNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_ROW = .
    Sep 2012
    Bump for any help. I'm assuming I'm missing something obvious that I need to do.
    Sep 2012
    Anyone?
    Mar 2007
    I believe the issue is that EFI Live is flagging these memory addresses as overlapping areas where it also has parameters. Thus, the software is trying to prevent you from accidentally making changes to the same section of memory. I have heard that this became an issue a while back, but I am not sure of the exact work around.
    This might not help, but when I noticed this starting to pop up, I just made sure and stayed on an older version of software where this was not an issue.
    Sep 2012
    I am on an older version of SW too. Dumb question, but I assume you can't just rename the names to something different that isn't used right?
    Mar 2007
    Yes, you can name the parameters any name as long as it is not used. Typically, most CAX files that I have seen have parameter names like D9xxx. Something that is way away from anything else in the calibration file.
    It might be worth a try?
    Sep 2012
    ill give it a shot and report back. If anyone else can confirm or has other info it would be much appreciated.
    Sep 2012
    EDIT-- That didn't work. I tried all sorts of addresses and get the same overlap error.
    Mar 2007
    stupid question - which version are you using? I know you said older, but how old? FWIW - I am still running version 7.5.7 build 230. I can't remember which version they started to add the additional checks to CAX files.
    Sep 2012
    I'm running 7.5.28. I don't see a build number anywhere on the "about tab of EFI Live".
  1. 4l80e tcc throttle close cax
    By TrendSetter in forum CAX Files
    Last Post: February 8th, 2023, 03:57 AM
  2. 12592618 b9021 CAX file
    By 5.7ute in forum CAX Files
    Last Post: January 19th, 2023, 02:57 PM
  3. Stop TCC unlock when coasting?
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 27th, 2010, 02:47 PM
  4. any 01/02 4l80e trucks NOT unlock tcc on decel
    By Cablebandit in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 4th, 2007, 02:35 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
