Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: 12592618 cax for 4l80e TCC unlock tables
  1. #51
    I use my lockup in 2nd-4th gear in tow haul and have it setup like this.
  2. #52
    Sep 2012
    Quote Originally Posted by nonnieselman View Post
    Excellent, Ill give that a try but I only lockup in 4th so Ill set my mph higher. Are you using a stock stall?
  3. #53
    Sep 2012
    Anyone ever see this? The MAF appears to be maxxed, but not at the max airflow of 512g/sec. It's like it reaches a certain amount and flatlines. Click image for larger version.
  4. #54
    Quote Originally Posted by ddnspider View Post
    yea Stock stall speed converter from Transstar. Its a BU52 part number in a 2500HD. Locking it up in 2nd gear at the right time makes it pull heavy trailers very good. But i dont try and lock it up unless TCC Slip is less than 500 rpms.
  5. #55
    Jan 2010
    Good thing I emailed them. They responded with:
    EFILive does not allow you to roll back or downgrade firmware.
    Please supply the cax you are trying to add and I'll have one of the engineers take a look.
    I sent over my files so hopefully they can help.
    Good to know on the firmware for future reference. I am also glad you emailed first.
    I see they also were very helpful in getting your file fixed up!!! That's also great to here.
  6. #56
    Sep 2012
    Yup they were SUPER helpful!!!
  1. 4l80e tcc throttle close cax
    By TrendSetter in forum CAX Files
    Last Post: February 8th, 2023, 03:57 AM
  2. 12592618 b9021 CAX file
    By 5.7ute in forum CAX Files
    Last Post: January 19th, 2023, 02:57 PM
  3. Stop TCC unlock when coasting?
    By LS1_Dragster in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 27th, 2010, 02:47 PM
  4. any 01/02 4l80e trucks NOT unlock tcc on decel
    By Cablebandit in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 4th, 2007, 02:35 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
