Hi Guys,
Im about to start on a 6.7 swap in a 02 F250, using a 68rfe trans. I did one about 8 years now and got it running perfe t using the PCM for trans control, but i had to use the dodge ABS module and mount a wheel speed sensor to give the ECM speed signal over CAN otherwise it reduced power.
Has anyone found a soloution to this yet without having to run the ABS module. Can we tune around it, or use a specific OS that we can hardwire a VSS to the ecm or Pcm.
