Results 1 to 2 of 2
Thread: LBZ Kodiak DSP5
    Jul 2022
    Default 2006 LLY Kodiak (E35A) DSP5 help
    So now I have figured out it is actually an LLY Kodiak with the E35A not an actual LBZ model. But still cannot figure out a DSP5 that will work with the thing. The stock read converted into a DSP5 results with no crank no start after flashing the DSP converted stock file.
    Found a couple that it took and would actually start up but I had every light on the cluster flashing and dinging and the gauges going haywire. I
    Last edited by Yaboy131; March 16th, 2023 at 06:09 PM. Reason: I was told it was an LBZ initially
    Apr 2022
    Ive got an 06 as well. It had a functioning dsp5 tune when i bought it but it had a s300 kit on it. I put a vgt turbo back on it. I got the same crank no start when i converted the stock file also. Im wondering if they used a Silverado file to get it to work correctly but i wonder if any of the stock kodiak functions would be lost. Did you find some way to get it to work or give up?
  1. 05 kodiak dsp5 tune identification
    By b18cls1 in forum Duramax LLY
    Last Post: October 22nd, 2022, 04:08 AM
  2. LBZ dsp5 $0331
    By stang_j_99 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2016, 03:28 AM
  3. lbz dsp5
    By 69camaro5speed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2011, 09:23 AM
  4. Lbz/lmm dsp5
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 10th, 2010, 03:16 PM
  5. DSP5 switch for LBZ
    By first timer 6.6 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 19th, 2010, 04:35 PM
