Results 1 to 2 of 2
Thread: Calculated AEM Wideband PID
    Feb 2023
    Default Calculated AEM Wideband PID
    Has anyone create a calculated pid for the AEM 30-0310 Wideband. I have been working for a week trying to make a CACL pid but have been totally unsuccessful. I just am not smart enough to figure it out upon reading the instructions in the Scanning manual. The math is close to the other Widebands but not the same. AFR is (2.3750*Volts) + 7.3125 where as Lambda is (0.1621*Volts) + 0.4990. Any help either with one someone has created or the "How To " make one.
    Thank you
    Jun 2005
    Quote Originally Posted by Lanny View Post
    Thank you
    Did you try the scanning tutorial section? Sounds like you have the formulas already. It's just a matter of whether you want to log Lambda or AFR. You could setup both. But, I'd suggest Lambda.
    https://forum.efilive.com/showthread...-WBO2-example)
  1. V8 Scanner Wideband input to EGR Calculated PID
    By nonnieselman in forum General
    Last Post: October 28th, 2021, 07:28 AM
  2. AEM wideband 02 support?
    By PRAY in forum Petrol / Gas
    Last Post: October 7th, 2012, 10:28 PM
  3. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 02:42 AM
  4. pids for AEM wideband
    By blazinblue in forum FlashScan V2
    Last Post: April 22nd, 2009, 04:04 PM
  5. AEM wideband gauges
    By madprof01 in forum External A/D inputs
    Last Post: June 5th, 2006, 09:34 AM
