Results 1 to 2 of 2
Thread: Surging on decel
    Mar 2022
    Default Surging on decel
    Hi everyone. I need some help on a 06 cummins. This is my brother's truck, and I tuned it for him. Cummins aren't really my specialty, I've done more with Duramax. Anyway, the truck has BD 33% over injectors, Industrial Injection 33% over CP3, and S363 turbo. The problem is, when you decel, especially after a pull in overdrive, the engine surges instead of returning to idle. I've attatched a log. You can see the pulsewidth and MM3 jumping around. The problem is much worse with the CSP tune set on tune 5 and almost nonexistent on tune 1, which is basically stock. I used a pulsewidth table from BD for the bigger injectors, but I didn't adjust for the oversize pump. Could that be my problem? If so, how do I do that?
    Mar 2022
    To answer my own question, I ended up copying the rail pressure and pulsewidth table lower sections into all 5 of the other tunes. That seems to have fixed the problem.
  1. rich on decel
    By andysc3 in forum Gen III V8 Specific
    Last Post: September 13th, 2012, 12:18 PM
  2. Decel Downshift
    By L31Sleeper in forum CAX Files
    Last Post: February 21st, 2010, 02:45 PM
  3. Rich decel
    Last Post: December 23rd, 2009, 07:14 AM
  4. Rich decel...still...also..etc
    Last Post: March 7th, 2009, 04:39 AM
  5. Idle/decel surging problem
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2006, 09:16 PM
