Results 1 to 1 of 1
Thread: Mar 23, 2023, V8.3.36 Public Release Candidate 3
    Default Mar 23, 2023, V8.3.36 Public Release Candidate 3
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V8 software: V8.3.36
    • FlashScan/AutoCal V3 Firmware: V3.00.105
    Download here:
    Known Limitations:
    Limitation #1: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Limitation #2: When opening CMF (CM2450B) Cummins 2022 tune files, the EFILive software will complain with the following message:
    That is expected and the message may be ignored. We have only added the option to open CMF 2022 stock files so that EFILive can flash stock files. EFILive cannot be used to update the check sums of modified files. Modified files cannot be flashed.
    Ignore the message if you are opening and flashing a 100% stock tune file. Do not attempt to flash a modified file, it will fail at the end of the flash and the vehicle will be left in a no-start condition until a stock file is flashed in.
    Workaround: None.
    Limitation #3: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), that are specific to a custom operating system such as DSP2 or DSP5 PIDs when running a stock operating system, the values returned by those DMA PIDs will not contain valid information and should be ignored.
    Known Issues:
    None.
    Regards,
    The EFILive Team
  1. Feb 22, 2023, V8.3.35 Public Release Candidate 2
    Last Post: February 21st, 2023, 12:43 PM
  2. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
  3. Release Candidate 10, Mar 11, 2012
    Last Post: March 28th, 2012, 12:52 AM
  4. Release Candidate 10 (updated), Mar 21, 2012
    Last Post: March 26th, 2012, 05:44 AM
  5. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
