Results 1 to 2 of 2
Thread: Sanity Check
    Mar 2023
    Question Sanity Check
    Hello,
    I am pretty new to doing tuning and just want to get a little sanity check from some experienced individuals out there before I go making changes that I could find myself unable to drive my vehicle.
    I have an E86B ECM, so as I understand it the only way to assign a VIN to my V3 is to load a tune package on there. I have a stock tune ready to go and I have the old tune from my tuner that I'm trying to work with. However there's a warning that pops up when I try to load the file from my tuner that has 4 restrictions:
    1. Cannot be modified - (Fine I'm not trying to make the changes here)
    2. Cannot be viewed - (Again I'm not trying to edit this file or copy it)
    3. Restricted to controller with VIN: (My VIN)
    4. Linked to remote AutoCal with License: (Assuming his license)
    Now if I use my V3 Flashscan to load a stock tune, this should then allow me to go back and load the tuners tune because my V3 would have my VIN assigned to it...
    Is that correct? Or am I misunderstanding something?
    Dec 2005
    Incorrect
    If a stock tune has no restrictions for being linked to an autocal you can flash with a flashscan, any restrictions such as linked to remote device/autocal will prevent you from flashing with any device that does not have that license number
    www.mscservices.net
  1. Sanity check, please...
    By Rich Z in forum Gen III V8 Specific
    Last Post: October 7th, 2013, 05:13 AM
  2. Sanity check of logs
    By stigmundfreud in forum Gen IV V8 Specific
    Last Post: July 5th, 2010, 10:33 AM
  3. Sanity check please
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 11:52 AM
  4. Sanity Check on Commanded AFR
    Last Post: October 23rd, 2007, 02:34 AM
  5. Sanity check, please?
    By critter in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 01:14 PM
