Results 1 to 6 of 6
Thread: LLY Files
    Mar 2023
    Default LLY Files
    Does anyone have any files to help me get started?
    Mar 2022
    Here's a tow tune I ran in my truck for a while. It's real clean but makes nice power and has turbo braking.
    2005 LLY 60 HP Tow Tune.ctz
    Mar 2023
    Awesome Thank you! If you have a dsp5 switch can you set this file as one of the settings?
    Mar 2022
    Quote Originally Posted by Jtrent93 View Post
    Yes, in fact that's how I had it set up.
    You'll want to use your stock file for the base tune, then convert it to DSP, save and reopen, then you can copy tables from my tune to whichever level you want. For example, table B0720 would be copied to A1105 if you set up the tow tune as level 2, and so on.
    Mar 2022
    Also, here's the stock tune from my truck so you can compare it with the tow tune and see the changes I made.
    Stock LLY 927410.ctz
    Mar 2023
    ok ill play with it thank you for your help i appreciate it!
  1. Replies: 2
    Last Post: December 31st, 2018, 03:28 AM
  2. 06 LLY/LBZ stock files
    By ROADRAGE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 21st, 2012, 01:24 PM
  3. LLY Calibration Files
    By kodydog in forum Duramax LLY
    Last Post: January 18th, 2008, 03:13 PM
  4. Pre-Release LB7 & LLY calibration files for download
    By GMPX in forum General (Diesel)
    Last Post: September 25th, 2006, 09:19 PM
