Thread: Need help starting with fresh Cust OS & tuning right way for 2Bar Speed Density
Threaded View
    Oct 2003
    Default Need help starting with fresh Cust OS & tuning right way for 2Bar Speed Density
    So, I have a my car running decently but I did it by adjusting the VE tables.
    I just got my car back up and running (it's been sitting close to 4 or 5 years). I want to tune the right way.
    I have a 2009 Z06 block with Darton Sleeves, bored 30 over and stroked 4.125 making about 447 CID.
    I put in Injector Dynamics 1050x injectors, and programmed the injector data into the appropriate tables. They idle beautifully.
    The car makes great power, though I haven't leaned into WOT because it's still lean at near WOT.
    I took a 2002 Camaro (Auto Trans) calibration (12212156) and used the Custom OS documentation to put it into recommended OS. (I have a 2-Bar MAP Sensor installed and rewired 1998 to 1999+ PCM)
    I decided to try to start from scratch, once I thought I understood how I SHOULD approach the tuning (AutoVE first to get true Air Density, then use {B3647} Commanded Fuel vs RPM (Normal) to define the commanded fuel?) Is this correct?
    (I am Running Speed Density)
    My problem when I try to start from scratch, going Step by Step through the Custom OS Setup, the car won't crank... it turns over once then dies. I know it has something to do with fueling.
    (The Calibration I try to start with has new CID modified from 12212156 and the Transmission and Speedometer tables, fans speeds... stuff like that, modified.
    Attached is the Calibration I tried to re-start with.
    Last edited by Black LS1 T/A; May 24th, 2023 at 07:52 AM. Reason: Incorrect Calibration Attached
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
  1. Setting pu for speed density tuning
    By Madmax in forum Gen III V8 Specific
    Last Post: September 17th, 2020, 06:57 PM
  2. lm7 speed density tuning
    By 2003gmc1500 in forum Gen III V8 Specific
    Last Post: February 7th, 2017, 03:27 PM
  3. Tuning LS1 Superchared 02 TA with speed density and o2
    By RamAir in forum Gen III V8 Specific
    Last Post: October 30th, 2012, 02:34 PM
  4. Tuning Speed Density with Auto VE
    By supercharged88 in forum Gen III V8 Specific
    Last Post: September 9th, 2012, 07:14 AM
  5. Starting Fresh
    By semperfidoordie in forum Duramax LLY
    Last Post: September 7th, 2010, 02:40 AM
Tags for this Thread
