Results 1 to 4 of 4
Thread: Knock at low load
    May 2023
    Default Knock at low load
    Hi !
    I preparing to do the CALC.VET tuning but I get knock/retard at low load but i don`t know why. False or is it something strange in my settings?
Name:	Knock low load.JPG
    Nov 2014
    always good to check burst knock. i doubt it would set in at 12% tp though. where is your spark and vss? i cant read the labels.
    (you seem to have the same problem iv had with the logging software for many years now, the layout close to impossible to manage.)
    Can you hear it?
    ( yes, takes alot of effort to manage )
  1. 4l80e swap, converter making noise at low load? Line pressure?
    By jay_rich in forum Gen III V8 Specific
    Last Post: June 22nd, 2015, 04:58 AM
  2. Is 45* too high for low load low rpm cruising?
    By the Dragon in forum General
    Last Post: February 13th, 2011, 01:43 PM
  3. What caused this low rpm knock ?
    By wesam in forum Gen III V8 Specific
    Last Post: July 15th, 2010, 12:13 PM
  4. Excess Timing in low load areas causes surge/buck issues, and how I fixed it.
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2008, 12:08 PM
  5. Negative Timing in High Load and Low RPM areas?????
    Last Post: February 18th, 2008, 02:55 PM
