Results 1 to 5 of 5
Thread: Need a tuner to enable electric fans on 2500 tune that came without
    Apr 2011
    Default Need a tuner to enable electric fans on 2500 tune that came without
    2010 Suburban 2500 - stock no e-fans.
    Bought 2009 Silverado electric fans, wired everything in stock locations, discovered electric fans cannot be enabled with EFILive for E38 tunes that didn't come with electric fans from the factory.
    Send me a PM if you can help! Thanks-
    hi
    here changed:
    fan type switched to PWMelectric
    number of fans fitted: 2
    fan PWM freq switched to 128Hz
    Apr 2011
    Thank you! Will give it a shot today ��
    Apr 2011
    This makes them come on, but the relays buzz like crazy. I believe I need to use the discrete setting for the factory truck style setup. When I switch to discrete, the fans don't turn on. I think it's getting there though.
    Apr 2011
    I think I got it! Found 2010 6.2 denali uses same OS. I was able to segment swap "system" into mine. I think it's working!!
  1. Enabling Electric Fans on LQ4 Yukon
    By C10Racer in forum Gen III V8 Specific
    Last Post: December 18th, 2017, 07:40 PM
  2. Electric fans
    By Kunz111 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 31st, 2015, 03:25 PM
  3. electric Fans
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2013, 06:01 PM
  4. Who's converted an '02 6.0 truck to electric fans?
    By HTMtrSprt in forum Gen III V8 Specific
    Last Post: March 9th, 2009, 02:58 AM
  5. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 11:14 PM
