Results 1 to 2 of 2
Thread: C7 Z06 registering knock but no timing pulled
    Apr 2010
    Default C7 Z06 registering knock but no timing pulled
    hi all, so i'm trying to get more into the E92 (big transition from LS1B) and was recording the recommended spark advance and KR PIDs.
    What I noticed, if true is that the are is really running around 25 deg timing WOT >5000rpm, I didn't expect that. On all my recent runs cat overtemp always comes on, even if I've only just started driving (warm car). Anyway, I saw a clear knock spike of 4 deg register but spark advance didn't move, on the LS1B I could always see the KR subtracted out of the spark advance. Does the E92 filter this as it occurred almost directly related to cat overtemp kicking in?
    I'm running 98 ron octane (and can even go up to 102) as i'm in Germany and we have unlimited speed on some stretches of highway, this was a 4th gear pull, circa 200km/h
    Jul 2003
    Knock is slightly different on E92. it is NOT global like E38. So you are likely seeing the biggest knock detected on a specific cylinder. The SAE Spark PID measures the retard on cylinder one. There are a few PIDs that can tell you which cylinder it is.
  1. Long Term Spark Trims? What Happens When Timing is Pulled Due to Knock?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2015, 09:57 AM
  2. Timing being pulled with no knock detection
    By GLGJR in forum E37, E38 & E67 PFI ECM's
    Last Post: September 8th, 2010, 12:39 AM
  3. What could cause timing to be pulled with no KR detected?
    By ArKay99 in forum Gen III V8 Specific
    Last Post: September 15th, 2008, 10:09 AM
  4. No KR, but timing pulled on launch
    By efizjb in forum Gen III V8 Specific
    Last Post: February 6th, 2008, 03:25 PM
  5. Timing being pulled, but where?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2006, 05:19 PM
