Results 1 to 3 of 3
Thread: 2020 CMF Help
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Default 2020 CMF Help
    Version v8.3.38
    Firmware 2.08.194
    Boot 2.08.009
    2020 Ram 2500 68RFE
    Flashed modified file into the truck and went through as expected. Truck would not start and has dash gremlins. Can still communicate to the ECM it appears but no data showing on any PID's. When reflash is attempted it goes through the 100% checking, then says security unknown. after that is says erasing and immediately aborts with $0311. does this with modified and stock files. I do not have a bench harness to flash with. any ideas or tips to try before I send it out to be recovered?
    Jul 2018
    https://forum.efilive.com/showthread...trollers/page2
    Have you tried pulling fuses to calm down the bus?
    Sent from my SM-S908U using Tapatalk
    Jun 2011
    yes, I have. I saw that thread, but it is a different error. everything always ends the same. efilive is for sure seeing the ecm as autodetect is working and it begins to erase but that's as far as i got. currently got batteries unhooked in a last-ditch effort before I send off for recovery. this is a basic bighorn model so not even loaded up with modules. bone stock too.
  1. Error $0331 when flashing CM2450B (CMF) controllers
    By Blacky in forum Cummins 6.7L
    Last Post: August 2nd, 2023, 08:59 AM
  2. 2021 CMF IA80062.01 stock file
    By Yaboy131 in forum Cummins 6.7L
    Last Post: July 1st, 2023, 08:57 AM
  3. CMF 2450 VIN Change
    By trucks in forum Cummins 6.7L
    Last Post: February 24th, 2022, 02:35 AM
  4. CMF 2019/2020 CSP-5 Issue
    By cumminstuner in forum Cummins 6.7L
    Last Post: March 9th, 2021, 01:11 PM
  5. Merry Christmas 2020
    By joecar in forum Lounge
    Last Post: January 9th, 2021, 02:25 AM
