Results 1 to 10 of 13
Thread: AFR and air density altitude?
    Default AFR and air density altitude?
    Hi,
    I don't recall having seen any posts concerning the relationship between AFR and air density altitude. Air density certainlly has an effect on a car's performance, but what is the best way to make corrections? I'm thinking small changes in the PE table but others might have a better solution.
    Also is there any rule of thumb to use when making changes according to changes in the ADA?
    Tony
    Jun 2005
    I was under the impression that if the MAF is completely dialed in, it should adjust the fueling for you as your altitude changes. The car will also reference different points of the VE table as the density/altitude changes. However, the MAF tends to be more consistent from everyone I talk to.
    The other thing the car does to account for altitude and pressure changes is reset its barometer every time you start the car or go WOT. This helps keep the injectors in line while atmospheric conditions change.
    Jan 2005
    MAP sensor measure manifold absolute pressure, while MAF measures the incoming airmas. If you tune is dialed in, theoretically, it wouldn't make a difference if you were in Denver (85-95 kPa) or Houston (95-105 kPa).
    That's very interesting. Does that mean that we are better off NOT running in OP with the MAF disconnected as in a SD tuning mode ?
    Tony
    Jan 2005
    Op?
    Oct 2004
    Must mean Open Loop (l key is close to p)
    Andrew
    EFILive Crew
    Jun 2005
    Open loop simply means there's no feedback from the O2's during stoich cruise (14.7AFR). If you can, you should run closed loop incase changes from day to day decide to alter your tune. As far as running speed density (no MAF), that's a constant debate. I'm pro MAF and have my tune set to run awesome with the MAF. Others have a different opinion sometimes and then there are the few running so much boost that they can't use the MAF. I figure if you can use it....use it. SD should be left for those running forced induction that would normally max out the stock MAF.
    Recently I went to one of the classes at EFILive University. One of the things the instructor told us was that we should tune our cars in SD (OL) and leave it there. I questioned him and he affirmed that that was what he meant. What you are saying though makes more sense.
    Tony
    hi tgeers ,
    Some comments about what you said...
    SD = speed density (uses RPM and density calculation) = MAF-less
    OL = open loop (ignoring O2 sensors)
    You can have OL and SD together.... OLSD
    Using my GM tune I run OLSD all the time, this is how I dialed in my VE table;
    or some others run OLSD using a custom OS (COS3, COS5);
    others dialed in their VE in OLSD, then dialed in their MAF, and now run with MAF (can have OLMAF or CLMAF);
    can run either way, pros/cons to each, they're all good, neither is wrong.
    VE table has units g.K/kPa... it takes temp. and pressure into account (as long as the VE is dialed in and the IFR table is correct).
    Hi JoeCar,
    I always appreciate your comments. Thanks
    Here is what I have done to tune my Corvette.
    I started with the OLSD. I set my command fuel in OL (B3605) high enough that my PE would always be governed by PE modifier based on RPM (b3618). This was easier for me. I began with PE set at 1.0 and turned my attention to the VE table. My goal was to get my base Efficiency 1-LM1 map to average as close to 1.0 as I could get it. That took a lot of doing but my numbers range from 1.0 to 1.08. Next I worked with my PE table. I wanted to idle at 14.6 (1000 rpm) then run a bit lean in the low rpm/map numbers (1500-2500 rpm/30-55map) for fuel economy. But when I accelerate I tried to get an AFR reading of 13.8 (2500-3500 rpm)(Map over 55). 13.8 AFR is a good acceleration number for my car. Then at wot I've been trying to maintain a 12.5-12.8 AFR throughout the 3000-6800 rpm range (map 95-100). Right now I am trying to leave the VE table alone and make my fine adjustment with the PE table.
    I'd appreciate your comments on this approach.
    Last edited by joecar; August 13th, 2006 at 06:43 AM. Reason: Fixed unintentional smilie 8)
  1. WOT AT 10,660' MSL..Density Altitude 14,000' MSL..
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: May 28th, 2010, 01:51 PM
  2. SD Tuning and altitude
    By bmax in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 05:37 AM
  3. High Altitude Tuning
    Last Post: July 21st, 2008, 09:17 PM
  4. Effect of altitude on tunes
    By Thumper in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2008, 12:02 PM
  5. Altitude change
    By C5 TT in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 7th, 2008, 08:29 AM
