Results 1 to 2 of 2
Thread: LS1B with TH350 swap
    Member TorqueMonster007's Avatar
    Aug 2013
    Default LS1B with TH350 swap
    If someone could take a look at this just to double check as it's been a while since I've had to setup an LS1B for a TH350. Keep in mind that this is a base file and has not been logged yet nor adjusted as such. Car also has a Victor Jr. intake, factory MAP and MAF still being used. Any input or verification would be appreciated. PO740, PO753, P0785 and P1860 have not been removed yet from Trans Diagnostics but will be.
    2024 3500HD (SRW) Duramax Denali Reserve
    2021 Ram 4500 Limited (Horse Hauler)
    2016 LML 2500HD Duramax High Country with a little help
    2022 Yukon Denali
    Quote Originally Posted by TorqueMonster007 View Post
    Here is a tune i did for a guy with a TH350 and took awhile to get it to come back down to idle after being brake stalled and such but it turned out pretty good.
    This one is Speed Density tho.
  1. 4l60e to th350 swap
    By kevin49 in forum Gen III V8 Specific
    Last Post: August 17th, 2018, 05:20 AM
  2. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  3. 2007 E67 with TH350 trans
    By agault45 in forum Gen IV V8 Specific
    Last Post: June 21st, 2016, 10:51 AM
  4. LS1B swap into Chevy 3100?
    By Wheelz in forum Gen III V8 Specific
    Last Post: May 19th, 2013, 01:16 PM
  5. idle question with TH350...yes i have searched
    By acrider2 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2009, 04:43 PM
