Results 1 to 8 of 8
Thread: Segment swap /fan issue for OS 12656198?
    Dec 2021
    Default Segment swap /fan issue for OS 12656198?
    Does anyone have a compatible segment for this OS? Or able to segment an OS in to get the fans to work? I can't get the fans to come on with temperature. I applied the patch and i can get them to activate with DVT, but they refuse to come on with engine temp. Doing a bunch of reading, i think that may be my issue. Here's my current tune file:
    Thanks!
    Are you retrofitting efans to a non-factory efan application? If so, there are tables you need outside of EFILive to accomplish this. The Fan Patch just rescales the ECT axis so you can control the start point lower, it doesnt update things necessary to control an efan.
    Dec 2021
    Yes I am. Donor vehicle had engine driven fans. How do I add the tables to get E-fans to work?
    2014 Chevrolet Camaro Coupe Manual LS3 6.2 Litre (12656198).ctz
    do a segment swap from this & see if it works for you
    Dec 2021
    I've tried that file, it doesn't start after I swap the "system" portion- even after removing VATS. I tried removing it before and after segment swap, for some reason it doesn't work.
    have you got the clutch pedal position sensor installed/wired to the ecu or have you tried turning off the clutch check?
    Dec 2021
    I have not. It's set to "yes" on my other tune, I didn't think much about it. I can try it. When I say it doesn't start, it will crank, but not fire.
    Quote Originally Posted by Tobyj177 View Post
    ah ok. so your wired to starter directly then. sounds like a vats issue. sometimes you need to play with the settings to get them going. just turning off vats doesnt always work. you might need to play with the vats type option.
  1. Help with segment swap
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: March 17th, 2018, 08:39 AM
  2. Need help with segment swap
    Last Post: February 19th, 2018, 03:34 PM
  3. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  4. How do you do a segment swap?
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2012, 08:18 AM
  5. Segment swap...Q's???
    Last Post: November 6th, 2007, 07:14 PM
