Results 1 to 4 of 4
Thread: No start after segment swap
    Dec 2021
    Default No start after segment swap
    At my wits end here.. Can anyone help me out with why this thing won't start after a "system" segment swap? Trying to get my fans to work. Using the same OS as what i have, but if i install the segmented tune, it doesn't fire. Runs fine if i put the original system segment back in. System segment is from a manual trans car...what I have is a 6L90. would that matter? File for reference:
    Think you posted on FB as well. Need more info, is this a factory application or swap? You can't mix n match auto and manual stuff, that's partially defined in the System segment (and others).
    If you want to get your fans to work, assuming efans in non-factory efan application. You need parameters modified that are not in EFILive, either need to have someone add via .cax, patch it yourself if you know the parameters/tables, or use another tuning platform for this part.
    Dec 2021
    I did post on FB as well. So, I have no clue how to do anything with cax files. Does this same problem exist with HP tuners?
    Not to over simplify it, but there are TONS of things defined in the System segment, a bunch of which we (the aftermarket) still don't know what they do. Don't swap segments unless you absolutely need to, especially in Gen IV+.
    If you're only trying to get efans to work, yes other suites have the necessary parameters defined to accomplish it.
  1. Help with segment swap
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: March 17th, 2018, 08:39 AM
  2. Need help with segment swap
    Last Post: February 19th, 2018, 03:34 PM
  3. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  4. What does a segment swap do?
    By Mean Green Z28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 6th, 2016, 07:52 AM
  5. A4 to M6 segment swap help
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2009, 10:24 AM
