Results 1 to 10 of 17
Thread: 2009 Truck E38 with manual transmissiion
    Senior Member Naf's Avatar
    Aug 2006
    Default 2009 Truck E38 with manual transmissiion
    I read all the posts, and searched. My only issue is I have to use the truck OS as I am using a gmlan converter to operate the cluster/instrument dials.
    I tried the 2009 corvette os with a manual trans, and the gmlan converter did not work.
    Besides me dumping another $100 on experimenting with another OS, does any one have a correct OS that has uses the trucks gmlan but has a manual trans?
    American Muscle, European Design, Japanese Tactics
    Changing the OS does not cost anything. Make sure the new OS is compatible with the current software in the ECM.
    Al
    Aug 2006
    Quote Originally Posted by ChipsByAl View Post
    Al
    You are correct, and I forgot to mention it was done prior with Hptuners, I know rivals, but I use both platforms, and ea has its Pros and Cons. HPT charge by the os, and iIf I were to do it with EFILive, I would have to license my ecu and that is still more money.
    I searched and its a common problem, I would have to use the Corvette OS but the gateway I am using doesn't have the protocol for the Vette, just the truck gmlan. So its either run the cluster and no cruise control, or have cruise control and no cluster...
    have you tried doing a segment swap rather then a full tune swap?
    Aug 2006
    How could I do that? If the OS are not similar it will not accept a calibration write.
    In theory, you are sayin keep the truck file, but do a calibration write of the corvette file?
    is there a similar os number that has the required manual option is what i mean. u could then just do a segment swap of the system segment. that seems to be the bit you need to swap.
    Aug 2006
    Doesnt work, tried that first. The truck os is looking for a gmlan trans speed signal. Its not there. So it maxes out the speedo, and goes into limp mode.
    what os are you using. i'll see if i can find anything if it's not defined already in efilive.
    Aug 2006
    Current OS is 12630501
    forgot to ask before what was the corvette os you tried too.
  1. Stock Manual Trans Tune, 2009-2010, ECM 5258003
    By LongNosePete in forum Cummins 6.7L
    Last Post: August 18th, 2023, 12:34 AM
  2. Truck 5.3 e38 tune for manual trans
    By LS-SWAPPER in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2016, 12:45 PM
  3. 2009 Sportwagon Manual E38 Cal ID 12633015
    By Wanga1969 in forum Gen IV V8 Specific
    Last Post: November 4th, 2014, 10:27 PM
  4. Replies: 3
    Last Post: June 25th, 2014, 04:02 AM
  5. 2009 HHR Manual Trans E37 Tune Help
    By joeboston in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2011, 02:17 PM
