Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: tune for 2011 Chevy Silverado
  1. #21
    Hopefully its a decent one.
  2. #22
    Junior Member Rwhite85's Avatar
    Aug 2023
    messed with spark at idle closed and have it around 16 and sounds good most the time i cant wait to get my wide band and play with fueling at idle it smells really rich and add to that its getting cold have not messed with it really about to start again also took out the cats. changed the oil and all looks good getting it tested
  3. #23
    Your narrow bands will tell you if its rich or lean.
    Are your fuel trims reading crazy?
  4. #24
    Aug 2023
    not really looked but i will check it out can you explain what i need to watch sorry its been so long hope u guys are still around
  5. #25
    Just datalog Long Term Fuel Trims and Short Term Fuel trims.
    Get it up to temp and just watch the trims. If they are constantly in the negatives more than 5% then it needs less fuel. If its in the Positives more than 5% then it needs fuel removed.
    Think of your factory oxygen sensors to be more accurate at part throttle than Wideband. And Wideband only when in PE.
  1. 2015 Chevy Silverado 5.3 help
    By Shophelper in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 5th, 2022, 07:05 AM
  2. chevy silverado tire size tune having problems
    By bensalz1911 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2018, 04:46 AM
  3. 2010 chevy silverado tire size tune
    By bensalz1911 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 22nd, 2018, 09:23 AM
  4. 2011 chevy silverado 4.8
    By Neal S. in forum Tips and tricks
    Last Post: July 27th, 2014, 08:56 AM
  5. 2011-2013 Chevy Volt
    By cmturn0 in forum Do you want to be a Beta Tester?
    Last Post: January 9th, 2014, 02:17 PM
