Something is pulling timing on me but I don't see where. I have WOT timing set to 22* but I am seeing it fall as low as 13* during a run. A0010 does not kick in until 175kPa which will never happen with a 3.25 pulley at these ambient temps.
I have logged all of the spark PIDS.
On a recent log the only activity I saw was: IAT spark -1.5* max and KR 1.5* max but both did not occur simultaneously. Only the -1.5* IAT spark was active when spark advance was at the minimum of 13-14*(ambient was 35*C and IAT climbed to 81*C under boost). So I should still have seen 22-1.5=20.5* of advance.
Tonight ambient was 23*C. WOT timing logged at 18.5*-19* with no KR. Didn't log IAT spark though. A couple of months back, when I first bumped the timing up to 22*, that's exactly what I saw when logging.
I've checked all the multipliers as well.
Is there anywhere else that I can look?
