Results 1 to 3 of 3
Thread: Cmf cp3 os
    Sep 2019
    Default Cmf cp3 os
    Are there any plans for updated CSP5 OS's for 21+ trucks, or 19-20s with the CP3 recall done?
    I am having trouble getting it to run properly with the CP4 OS, even with fuel psi tables changed to CP3 values. I am assuming there are more fuel tables that are unmapped by EFILive that need to be changed to run properly.
    Oct 2023
    yes there are well over 20-30 parameters in the back end in BIn that need to be changes in order to convert to a true CP3 file.
    Nov 2009
    Uh there's 44. Jim P first posted that a while back ago, took me a little bit but I got them all found and it makes truck idle much smoother without the ticking. Where you will notice a big difference is on the 22 and 23 trucks. A cp4 file on those trucks is very loud with harsh idle this is compounded by the fact that the 22 up trucks have different injector calibrations from the 19-21. I have those as well in my 22,23 files.
  1. Error $0331 when flashing CM2450B (CMF) controllers
    By Blacky in forum Cummins 6.7L
    Last Post: August 2nd, 2023, 07:59 AM
  2. 2020 CMF Help
    By comnrailpwr in forum Cummins 6.7L
    Last Post: August 1st, 2023, 04:14 AM
  3. 2021 CMF IA80062.01 stock file
    By Yaboy131 in forum Cummins 6.7L
    Last Post: July 1st, 2023, 07:57 AM
  4. CMF 2450 VIN Change
    By trucks in forum Cummins 6.7L
    Last Post: February 24th, 2022, 01:35 AM
  5. CMF 2019/2020 CSP-5 Issue
    By cumminstuner in forum Cummins 6.7L
    Last Post: March 9th, 2021, 12:11 PM
