Results 1 to 6 of 6
Thread: Lean Cruise 2002 Vette
    Jul 2005
    Default Lean Cruise 2002 Vette
    For those of you using the Custom OS, how lean (AFR) are you running your off idle, low RPM, low MAP to achieve lean cruise.
    What I am looking to do is direct a lean cruise AFR at 1000rpm-2000rpm - MAP range to be determined by some logging at 50mph-90mph cruising.
    Am I approaching this the right way?
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Jul 2005
    Bad on me. Did a search and seems 15.3-15.4 is about as lean as I should go.
    Comments from you guys tunning lean cruise?
    Lonnie
    2002 EB Coupe, MN6
    Oct 2005
    Yeah thing is when you are on light throttle, but in decel. dfco isnt working and anything leaner than about 16:1 will cause some jerking action.
    Take a look at an AFR power curve, you can go to 15.4:1 and not lose much power at all. So maybe use it at most cruise points under idle map and perhaps low rpm up to around 70kpa.
    I used to run like that, but now I need a little richer as my cam gets upset without lots of food to eat.
    2014 VF SV LS3 Maloo.
    Jul 2005
    Thanks ringram. Had that bucking till I did Idle Transistion Tuning, don't want it back. Will post something once I get this tune finished. (or at least to the point where I am not driving around with a computer in the passenger seat....ha ha)
    Lonnie
    2002 EB Coupe, MN6
    Jul 2003
    I have run it till 16.5:1. the problem is not that you lack power, but that if there are not many squares in that table, the lookup will fluctuate too much between cruising conditions, affecting the commanded AFR and you will notice some surging. If you can keep it steady @ 16.5:1 all the cruising time... well it will work fine.. From what i have tested.. 15.5:1 is the best because it doesn't loose that much power like ringram said.
    Jul 2005
    Thanks for the input guys. Nothing like a little re-enforcement before you start leaning things out. Aluminum melts so easy
    Lonnie
    2002 EB Coupe, MN6
  1. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  2. Lean cruise patch working for 2003 A4 Vette OS 12221588
    By Treurentner in forum Tuning For Economy
    Last Post: October 22nd, 2008, 04:28 AM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  4. lean cruise in OS3
    By horsepower1 in forum Custom Operating Systems
    Last Post: November 14th, 2006, 02:33 AM
  5. Replacing MAP 2002 Vette
    By lplott in forum Custom Operating Systems
    Last Post: May 30th, 2006, 10:02 AM
