Results 1 to 10 of 13
Thread: P59 ls1b cos5 setup help!
    Member TJWells's Avatar
    Apr 2008
    Default P59 ls1b cos5 setup help!
    I have a 2002 Z06 originally a 411 pcm. I am switching over to a P59 ECM # 12589162 with OS# 12592618. I need help deciding which os to use. This is an ls7, I'm using a lingenfelter box to convert the crank and cam signals. I would like to use cos5 for nitrous in the future. Also running Flex Fuel. My thoughts were to load cos5 and then copy the tune files from a 2004 z06 file. I have already repinned the ecm connectors. I found a chart to choose the COS# 051200##. Just looking for some direction on a gameplan. Thanks for any help.
    Apr 2008
    Any Help would be appreciated!
    COS5 is available only for OS 12212156 on the 0411 PCM.
    Apr 2008
    So I can't use my p59 ecm with a cos? my operating system is 12592618 can't I use 051200xx per the tutorial?
    That is correct. You only have access to Custom Operating Systems 01, 02 & 03 with the P59. You could go back to the earlier PCM and run OS 12212156 and COS 05.
    Al
    Apr 2008
    Ok.. so can I run e85 on the 411 pcm? This is a 12:1 motor, it would respond well to e85. If so can you direct me to what I need to to do to add the tables for e85.
    May 2014
    Also, why the 12592618 OS? Why not the default 04 Corvette OS?
    Apr 2008
    The p59 ecu I have{that I can use with e85}has that os in it. I have no complaints about using the 04 OS. I just need to know the best choice to get this car running with e85 and nitrous. That may be the 04 OS. I have tried to find a local tuner willing to sell me a base flash to get this car running to bring it to a shop. No one wants to do it. not sure why. So I'll just do it my self. I've done some tuning with my 06 z06.
    May 2014
    Yeah you'll want to use the 2004 C5 as your base file to make life easiest and keep fuel gauges and everything working as expected.
    You'll just need to enable FF on it, but I posted the cax files and a FF enabled 04 C5 tune here to start working with: https://forum.efilive.com/showthread...Corvette-Files
    To run the P59, you'll probably need to move the alternator pin in the harness and disable a few of the O2 related codes. Some additional info located here: https://www.corvetteforum.com/forums...uel-on-c5.html
    But as already mentioned, there is no COS5 for P59.
    You can keep your stock PCM and run COS5, but you won't have a good option to run flex fuel. E85 only tune is no problem, but I don't know how consistent your E content is around there...could be troublesome if it varies a lot and no flex fuel function.
    Not sure what the best option is for you in your case, but those are some pros/cons I can think of!
    Apr 2008
    Now this is the help I needed. Thank You. I already switched pin 52 to 75. switched to green covers on connectors. just gotta do the o2 heater circuits yet. Sounds like I should use the p59 ECM. Is there a COS like 3 maybe? that I can use to control nitrous? with the p59? If not then I guess I could use an aftermarket timing control.
  1. P01 vs P59 for GMT400
    By Thelochnessmonstah in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2021, 04:57 AM
  2. Read DTCs on LS1B bench setup?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 6th, 2021, 11:48 AM
  3. Bricked P59 tune
    By greasess in forum Gen III V8 Specific
    Last Post: August 3rd, 2020, 05:26 AM
  4. COS5, how do I setup a 2 step?
    By tdmkr496 in forum Custom Operating Systems
    Last Post: August 26th, 2014, 06:22 AM
  5. COS5 and nitrous setup ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: June 2nd, 2008, 12:36 PM
