Results 1 to 4 of 4
Thread: 12 cummins 6.7 base tune request
    Nov 2023
    Default 12 cummins 6.7 base tune request
    If any kind users could send me a stock file for a 12 Cummins 6.7 I'm working on it would be greatly appreciated.
    cm2200
    p/n 5268444
    d/c: 10-11-2011
    esn 58077168
    e/c: cm90018.03
    i have access to efi live flash scan v3
    hp tuners mpvi3
    and wii tech via j2534 (which I had to purchase subscriptions to and reflash already after attempting to read the file not knowing this pcm was locked which rendered it uncommunicative / no crank)
    since i paid for the factory file maybe someone could direct me to which sub folder if any the stock file could be pulled and coverted for use with efi live or hp)
    Aug 2017
    Nov 2023
    Default thank you
    Quote Originally Posted by kev789 View Post
    much appreciated, will there be any effect on immobilizer when used?
    Nov 2009
    efi won't effect the immobilizer parameters, they don't flash those addresses.
  1. Base file for Cummins qsb480 5.9l
    By fgronlun@hotmail.com in forum Cummins 5.9L
    Last Post: July 29th, 2021, 05:31 AM
  2. Locating a 2017 6.7L Cummins base file
    By jk1956383 in forum Cummins 6.7L
    Last Post: November 29th, 2017, 05:57 PM
  3. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
