Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: ls1b fuel limit?
  1. #11
    Nov 2014
    have you ever tuned an ls7 for boost?
  2. #12
    LS7 comes in them expensive cars hahaa
    I mainly fool with truck stuff with cheap 5.3s or 6.0s. And build 408 or 427s for race cars.
    But ive done a few dozen Dart Block 427s in these light weight race cars but we running M1 in all of them.
  3. #13
    Nov 2014
    i should have asked about the e38 instead of ls7, i guess. comming from the po1, i wonder how steep of a learning curve it is. the project has been on a backburner for a while, because i cannot find the time.
  4. #14
    I struggle with all the Gen 4 stuff sometimes. The Gen 5 i only tune for DOD Deletes and stock everything else. They are too complex for me.
    E38 can be quite a chore to deal with if your only use to the LS1B pcms.
    I have some write ups on how to fool with them but the last few that i tried to tune with decent size cams always had quirks i never could figure out. I have a buddy that owns a performance shop that does tuning on all the newer Gen 4 and gen 5 stuff so i send them all his way. he sends me his customers that have Holley ECU's and older LS1B pcms.
    Thats how i get around that curve ball.
  5. #15
    Nov 2014
    and another number yet:
    "not sure how it does the caculations....i was seeing 2.09 g/per cyl @ 13.X psi when it set code" (p1514)
  1. Getting Virtual Flex Fuel Sensor to Work on LS1B 2005 Escalade
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: June 16th, 2020, 09:18 AM
  2. LS1b 12606807 OS- what maps can limit throttle blade position
    By Jetmech442 in forum Gen III V8 Specific
    Last Post: August 1st, 2014, 10:32 AM
  3. Fuel and RPM limit question...
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 2nd, 2010, 11:56 AM
  4. HELP! can't keep off the rev-limit/fuel-cut
    By white2001s10 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 27th, 2007, 01:16 PM
