Results 1 to 7 of 7
Thread: 2007.5-2009 TCM Writable with EFILive?
    Senior Member Jim P's Avatar
    Nov 2019
    Default 2007.5-2009 TCM Writable with EFILive?
    This possible yet?
    Nov 2019
    Not concerned about mapping, I can handle that fine. Just curious if it can write.
    my reply below is more for the petrol vehicles with the 6l80's, so probably not the same for the diesel stuff.
    You can write to all years, but to swap between say 24243170 to 24249179. you require the pro tuning license.
    If you try and write anything never than 9179 to an 09 & below controller, if it will stay in recovery mode as the programming is incompatible. Same deal with any newer TCM & loading in an old OS.
    Nov 2019
    Ram Cummins section, talking about the 68RFE for the 2007.5-2009 model years
    Nov 2019
    I know the Aisin can be written to can checksum corrections made but no mapping is provided. Curious if the same is true with 2007.5-2009 68RFE. Mapping I can deal with. Well aware of changing OS on the Cummins trucks ECM’s. Not what I’m asking about here.
    Nov 2009
    Yep can write em
    Nov 2019
    opened up the 2009 file I got from an HP Tuners readout and it opens and sees its a NGC4 TCM but has no checksum correction available.
  1. 2007-2009 6.7l Cummins .ctz Stock file library
    By CumminsTwang in forum Cummins 6.7L
    Last Post: November 19th, 2019, 02:26 PM
  2. T43 2007-2009 OS Reflash Compatibility Question
    By OEMOBDII in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: November 7th, 2018, 10:42 AM
  3. Replies: 0
    Last Post: February 10th, 2017, 03:30 AM
