Trucks getting fixed how do I delete this thread? Lmao.
Do you have an AutoCal or FlashScan? Basically the tuner didn’t set up your device correctly and it doesn’t have the required files loaded on it.
If I was back home, just south of Calgary I would come help you out but I’m in Louisiana till end of next month
That error code means the BBX settings are incorrect. Install Efilive V8 on your computer, if you haven't already. Connect your Autocal to the computer. Open the F5: BBX tab in Efilive Scan and Tune. select Read at the bottom of the screen. Then look under the Tune tab and see if any controllers are listed. The one you need is CME CM3250B. Add that one if it isn't loaded already. Then select Program at the bottom of the screen. You should now be able to flash your truck.
I don't tune many Cummins trucks, and I've never bricked one, but on Duramax's, Efilive has a recovery mode if the previous flash failed. It just may get your truck working again.
Send me a pm, I can't send u one for some reason. Sounds like your autocal needs Bbx redone on it.
For some reason I can’t send you a message aswell.
The files are not bbx unfortunately
Yes efi live auto cal v3
The bbx needs to be set up on the autocal, the tuner should have done that before sending or before trying to write the tune to the truck
They used a AMDP tuning file I asked after talking to another tuner and he said they should be bbx I talked to the person that tried to tune the truck and he said they are not bbx files is there a way I can convert them to bbx files?
