Results 1 to 6 of 6
Thread: High/Low Spark Map
    Jul 2005
    Default High/Low Spark Map
    Just looking at G5x3 tune I downloaded some time ago. The Low octane table is somewhat higher than the High octane table. What's the purpose here?
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Jun 2006
    they probably only made changes to the high octane table and left the low octane table stock.
    2001 Arctic White Pontiac Firebird Formula M6
    LME 408, AFR small bore 225s, TSP 248/254 .622/.612 114+2 cam, FAST 90mm intake/NW 90mm TB, TR 1 3/4" headers, SLP Dual/Dual catback, Spec 3i clutch, 3.73 Motive Gears, EFILive Custom OS 5
    Jul 2005
    No, they actually advanced Low octane as much as 10 deg over stock in some parts of the table and a few degrees advanced past High octane. Seems to have been done on purpose.
    Lifetime Member johnv's Avatar
    Jan 2005
    Quote Originally Posted by purrvert
    Could be running mafless without custom op sys , so would look up low octane table only .
    Jul 2005
    Running with MAF, OS 12221588. Here's the tune.
    Oct 2004
    Strangely the professional tune I paid for (some years ago now) was the same, low octane tale higher than high octane. But, I think as in my case it has to be a cock up!
    Andrew
    EFILive Crew
  1. Spark High Octane table
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 02:53 AM
  2. Low-High Spark tables...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 27th, 2008, 03:30 AM
  3. Help my spark advance is too high
    By Big Block in forum Custom Operating Systems
    Last Post: April 25th, 2008, 04:48 PM
  4. high/low octane spark tables.
    By s10mods in forum Gen III V8 Specific
    Last Post: December 23rd, 2007, 12:44 PM
  5. Base Spark and Spark Modifiers
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2007, 04:33 AM
