Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: CMD Exhaust brake memory cax
  1. #11
    Senior Member Jim P's Avatar
    Nov 2019
    Code from a 2012 calibration for the exhaust brake switch save
    void FUN_0018fdc0(void)
    undefined uVar1;
    undefined1 *puVar2;
    puVar2 = &DAT_60010590;
    DAT_6000c774 = 0xfffa;
    FUN_00063070(&DAT_00011ace,0xfffffffffffffffa);
    uVar1 = T_CANC_Exhaust_Brake_Switch_Saved;
    CANC_Exhaust_Brake_Switch = uVar1;
    *(undefined2 *)(&DAT_ffffc20e + (int)puVar2) = 0;
    FUN_00063070(&PTR_00012b6f,0);
    return;
    undefined8 FUN_00198570(int param_1)
    undefined *puVar1;
    short sVar2;
    short sVar3;
    char cVar4;
    byte bVar5;
    ushort uVar6;
    ulonglong uVar7;
    longlong lVar8;
    undefined1 *puVar9;
    undefined1 *puVar10;
    undefined uVar11;
    puVar10 = &DAT_60010590;
    puVar9 = &DAT_60010590;
    sVar2 = DAT_6000c774;
    sVar3 = DAT_6000c79e;
    if ((param_1 != 0) && (*(ushort *)(param_1 + 4) < 5)) {
    param_1 = 0;
    uVar6 = CGW3_3FBH_Msg_Status;
    CGW3_3FBH_Msg_Status = uVar6 | 2;
    CGW3_3FBH_Msg_Timer = 0;
    if (param_1 == 0) {
    if (sVar2 != -7) {
    DAT_6000c774 = 0xfff9;
    FUN_00063070(&DAT_00011ace,0xfffffffffffffff9);
    CANC_Eb_Sw_Psd = '\0';
    if (*(short *)(&DAT_ffffc20e + (int)puVar10) != -7) {
    *(undefined2 *)(&DAT_ffffc20e + (int)puVar10) = 0xfff9;
    FUN_00063070(&PTR_00012b6f,0xfffffffffffffff9);
    if ((*(char **)(puVar10 + -0x3e04) != (char *)0x0) && (**(char **)(puVar10 + -0x3e04) != '\0')
    cVar4 = C_CANC_EB_Switch_Msg_Lost_Val;
    if (cVar4 == '\0') {
    uVar11 = 0;
    else {
    if (cVar4 != '\x01') {
    return 1;
    uVar11 = 1;
    T_CANC_Exhaust_Brake_Switch_Saved = uVar11;
    CANC_Exhaust_Brake_Switch = uVar11;
    else {
    CGW3_3FBH_Msg_Status = uVar6 & 0xffe9;
    puVar1 = *(undefined **)(param_1 + 8);
    CGW3_3FBH_Msg_Data_0 = *puVar1;
    CGW3_3FBH_Msg_Data_1 = puVar1[1];
    CGW3_3FBH_Msg_Data_2 = puVar1[2];
    CGW3_3FBH_Msg_Data_3 = puVar1[3];
    CGW3_3FBH_Msg_Data_4 = puVar1[4];
    uVar7 = ((ulonglong)(byte)puVar1[4] << 0x20) >> 0x22 & 1;
    CGW3_3FBH_Msg_Data_5 = puVar1[5];
    CGW3_3FBH_Msg_Data_6 = puVar1[6];
    CGW3_3FBH_Msg_Data_7 = puVar1[7];
    cVar4 = CANC_Eb_Sw_Psd;
    CANC_Eb_Sw_Psd = (char)uVar7;
    DAT_6000c774 = 0;
    DAT_6000c79e = 0;
    if (((int)uVar7 == 1) && (cVar4 == '\0')) {
    bVar5 = CANC_Exhaust_Brake_Switch;
    lVar8 = countLeadingZeros((uint)bVar5);
    CANC_Exhaust_Brake_Switch = (char)((ulonglong)(lVar8 << 0x20) >> 0x25);
    T_CANC_Exhaust_Brake_Switch_Saved = 0;
    if (sVar2 != 0) {
    puVar9 = puVar10;
    FUN_00063070(&DAT_00011ace,0);
    if (sVar3 != *(short *)(&DAT_ffffc20e + (int)puVar9)) {
    FUN_00063070(&PTR_00012b6f);
    return 1;
  2. #12
    Nov 2019
    from the last revision (rev 9) of a 2018 calibration, less "labeled" than the 2012
    undefined8 FUN_00222210(int param_1)
    byte bVar1;
    byte *pbVar2;
    byte bVar3;
    byte bVar4;
    char cVar5;
    short sVar6;
    short sVar7;
    undefined2 uVar8;
    byte bVar9;
    ushort uVar10;
    uVar10 = DAT_60072484;
    sVar6 = DAT_6000fd70;
    if ((uVar10 & 0x40) == 0) {
    param_1 = 0;
    uVar10 = uVar10 | 2;
    DAT_60072484 = uVar10;
    DAT_60072486 = 0;
    if (param_1 == 0) {
    DAT_6000fd70 = 0xfff9;
    DAT_60072124 = 3;
    DAT_60072123 = 0xf;
    else {
    DAT_60072484 = uVar10 & 0x2fe9;
    DAT_60072486 = 0;
    pbVar2 = *(byte **)(param_1 + 8);
    DAT_6007247c = *pbVar2;
    DAT_6007247d = pbVar2[1];
    DAT_6007247e = pbVar2[2];
    bVar1 = pbVar2[3];
    DAT_6007247f = bVar1;
    DAT_60072480 = pbVar2[4];
    DAT_60072481 = pbVar2[5];
    DAT_60072482 = pbVar2[6];
    DAT_60072483 = pbVar2[7];
    bVar3 = *pbVar2 & 3;
    DAT_60072124 = bVar3;
    DAT_60072123 = (char)(((ulonglong)bVar1 << 0x20) >> 0x24);
    DAT_6000fd70 = 0;
    bVar4 = DAT_6000b345;
    bVar9 = C_CANC_EB_Trlr_Count;
    if ((((bVar4 < bVar9) && (cVar5 = C_CANC_EB_Switch_Save_Enable, cVar5 == '\0')) &&
    ((DAT_6000b345 = bVar4 + 1, bVar3 == 1 || (bVar1 >> 4 == 5)))) &&
    (cVar5 = DAT_6000b346, cVar5 == '\0')) {
    bVar1 = DAT_6000fe0f;
    DAT_600b4b74 = bVar1;
    DAT_60072101 = (&C_CANC_EB_States)[bVar1];
    DAT_600b4b69 = (&C_CANC_DL_EB_States)[bVar1];
    DAT_6000b345 = 0xff;
    sVar7 = DAT_6000fd70;
    if (sVar7 != sVar6) {
    FUN_00068070(&DAT_00025484);
    uVar8 = DAT_6000fd70;
    FUN_00068070(&DAT_00025485,uVar8);
    return 1;
    undefined8 FUN_002257a0(void)
    byte bVar1;
    ushort *puVar2;
    bool bVar3;
    undefined4 uVar4;
    ushort uVar5;
    byte bVar6;
    char cVar9;
    longlong lVar7;
    ulonglong uVar8;
    uint uVar10;
    ushort uVar11;
    byte bVar12;
    ulonglong uVar13;
    byte bVar14;
    byte bVar15;
    int iVar16;
    ulonglong uVar17;
    longlong lVar18;
    undefined uVar21;
    short sVar20;
    int iVar19;
    undefined auStack_38 [2];
    undefined auStack_36 [2];
    undefined local_34;
    undefined local_33;
    undefined local_32;
    byte local_31;
    undefined local_30;
    undefined local_2f;
    undefined local_2e;
    undefined local_2d;
    undefined local_2c;
    undefined4 local_28;
    uVar17 = ZEXT48(&DAT_60012c20);
    uVar4 = DAT_6000fcb0;
    FUN_00067020(uVar4,auStack_38,&DAT_6000fcd4);
    FUN_00067020(*(undefined4 *)((int)uVar17 + -0x2f6c),auStack_36,uVar17 - 0x2f48);
    iVar16 = (int)uVar17;
    if (((*(int *)(iVar16 + -0x31a8) == 0) ||
    (cVar9 = FUN_00066570(*(undefined2 *)(iVar16 + -0x2e6e)), cVar9 != '\0')) ||
    (cVar9 = FUN_00066570(*(undefined2 *)(iVar16 + -0x2e6c)), cVar9 != '\0')) {
    uVar17 = 0xff;
    else {
    lVar7 = FUN_001079f8(**(undefined4 **)(iVar16 + -0x31a8));
    uVar17 = lVar7 + 0x28;
    if ((longlong)uVar17 < 0) {
    uVar17 = 0;
    else if (0xfe < (int)uVar17) {
    uVar17 = 0xfe;
    DAT_600722b3 = (char)uVar17;
    bVar12 = *(byte *)(iVar16 + -0x2e29);
    uVar13 = ((ulonglong)bVar12 << 0x20) >> 0x21 & 1;
    uVar8 = FUN_00225760(uVar17,uVar13);
    *(byte *)(iVar16 + -0x2e29) = bVar12 + 1;
    bVar6 = DAT_600722b2;
    DAT_600722b2 = bVar6 & 0x7f;
    bVar1 = (byte)((uVar13 & 1) << 7);
    DAT_600722b2 = bVar6 & 0x7f | bVar1;
    bVar14 = bVar6 & 0x3f | bVar1;
    DAT_600722b2 = bVar14;
    bVar12 = (byte)((uVar8 & 1) << 6);
    DAT_600722b2 = bVar14 | bVar12;
    if (*(byte **)(iVar16 + -0x3038) != (byte *)0x0) {
    bVar14 = DAT_600722b1;
    DAT_600722b1 = bVar14 & 0xcf;
    DAT_600722b1 = bVar14 & 0xcf | (byte)(((ulonglong)**(byte **)(iVar16 + -0x3038) & 3) << 4);
    if (*(char *)(iVar16 + -0x2e10) != '\0') {
    cVar9 = C_CANC_EB_Switch_Save_Enable;
    if (cVar9 == '\0') {
    *(undefined *)(iVar16 + -0x78db) = 0;
    *(undefined *)(iVar16 + -0x78da) = 0;
    *(undefined *)(iVar16 + -0x2e10) = 0;
    uVar21 = DAT_600b4b74;
    *(undefined *)(iVar16 + -0x2e11) = uVar21;
    DAT_600b4b74 = 0;
    bVar14 = DAT_600b4b74;
    DAT_60072101 = (&C_CANC_EB_States)[bVar14];
    DAT_600b4b69 = (&C_CANC_DL_EB_States)[bVar14];
    bVar14 = DAT_600722b0;
    DAT_600722b0 = bVar14 & 0x1f;
    bVar15 = DAT_600b4b69;
    DAT_600722b0 = bVar14 & 0x1f | (byte)(((ulonglong)bVar15 & 7) << 5);
    if ((*(short **)(iVar16 + -0x3060) == (short *)0x0) || (**(short **)(iVar16 + -0x3060) < 1)) {
    bVar3 = false;
    else {
    bVar3 = true;
    if ((bVar3) && (*(char **)(iVar16 + -0x3000) != (char *)0x0)) {
    if (**(char **)(iVar16 + -0x3000) == '\0') {
    lVar7 = 1;
    else {
    lVar7 = 2;
    else {
    lVar7 = 0;
    bVar15 = bVar6 & 0x39 | bVar1 | bVar12;
    DAT_600722b2 = bVar15;
    bVar14 = (byte)(lVar7 << 1);
    DAT_600722b2 = bVar15 | bVar14;
    uVar10 = 0;
    do {
    if ((byte)(&DAT_003364e4)[uVar10] == 0) {
    uVar17 = 0;
    break;
    if (**(ushort **)(iVar16 + -0x312c) == (ushort)(byte)(&DAT_003364e4)[uVar10]) {
    uVar17 = 1;
    break;
    uVar10 = uVar10 + 1 & 0xff;
    } while (uVar10 < 0x19);
    bVar14 = bVar6 & 0x31 | bVar1 | bVar12 | bVar14;
    DAT_600722b2 = bVar14 | (byte)((uVar17 & 1) << 3);
    if (((*(char **)(iVar16 + -0x2fd0) == (char *)0x0) || (**(char **)(iVar16 + -0x2fd0) == '\0')) &&
    ((*(char **)(iVar16 + -0x2fcc) == (char *)0x0 || (**(char **)(iVar16 + -0x2fcc) == '\0')))) {
    bVar12 = 0;
    else {
    bVar12 = 1;
    bVar1 = DAT_600722b1;
    DAT_600722b1 = bVar1 & 0xfe;
    DAT_600722b1 = bVar1 & 0xfe | bVar12;
    cVar9 = FUN_00066570(*(undefined2 *)(iVar16 + -0x2e70));
    if (((cVar9 == '\0') && (cVar9 = FUN_00066570(*(undefined2 *)(iVar16 + -0x2e72)), cVar9 == '\0'))
    && ((*(char **)(iVar16 + -0x2fe0) == (char *)0x0 || (**(char **)(iVar16 + -0x2fe0) == '\0'))))
    lVar18 = 0;
    else {
    lVar18 = 1;
    bVar12 = DAT_600722b1;
    DAT_600722b1 = bVar12 & 0xfd;
    local_31 = (byte)(lVar18 << 1);
    DAT_600722b1 = bVar12 & 0xfd | local_31;
    puVar2 = *(ushort **)(iVar16 + -0x30d8);
    if (puVar2 == (ushort *)0x0) {
    uVar21 = 0;
    else {
    bVar1 = DAT_600722b2;
    DAT_600722b2 = bVar1 & 0xef;
    DAT_600722b2 = bVar1 & 0xef | (byte)(((ulonglong)*puVar2 & 1) << 4);
    uVar21 = (undefined)*puVar2;
    DAT_60072183 = uVar21;
    if ((((*(byte **)(iVar16 + -0x2fb8) == (byte *)0x0) ||
    (bVar1 = **(byte **)(iVar16 + -0x2fb8), uVar17 = (ulonglong)bVar1, bVar1 == 0)) ||
    (*(int **)(iVar16 + -0x3198) == (int *)0x0)) || (**(int **)(iVar16 + -0x3198) != 0)) {
    DAT_60072126 = 0;
    else {
    uVar11 = DAT_60072126;
    uVar5 = DAT_60042a22;
    if (uVar11 < uVar5) {
    uVar11 = uVar11 + 100;
    DAT_60072126 = uVar11;
    if (uVar5 <= uVar11) goto LAB_00225b70;
    uVar17 = 0;
    LAB_00225b70:
    local_31 = bVar12 & 0xbd | local_31;
    DAT_600722b1 = local_31;
    local_31 = local_31 | (byte)((uVar17 & 1) << 6);
    cVar9 = DAT_60042a69;
    if (cVar9 != '\0') {
    *(undefined *)(iVar16 + -0x2e3c) = 1;
    DAT_600723b8 = (int)lVar7;
    if (*(short **)(iVar16 + -0x3054) == (short *)0x0) {
    sVar20 = 0xff;
    else {
    sVar20 = **(short **)(iVar16 + -0x3054) >> 6;
    if (sVar20 < 0) {
    sVar20 = 0;
    else if (0xfa < sVar20) {
    sVar20 = 0xfa;
    local_2e = (undefined)sVar20;
    DAT_600722b4 = local_2e;
    if (*(int **)(iVar16 + -0x3164) == (int *)0x0) {
    iVar19 = 0xff;
    else {
    iVar19 = **(int **)(iVar16 + -0x3164) >> 0xf;
    if (iVar19 < 0) {
    iVar19 = 0;
    else if (0xfa < iVar19) {
    iVar19 = 0xfa;
    local_2d = (undefined)iVar19;
    DAT_600722b5 = local_2d;
    if (((*(short **)(iVar16 + -0x3098) == (short *)0x0) ||
    (*(undefined2 **)(iVar16 + -0x30a8) == (undefined2 *)0x0)) ||
    (sVar20 = **(short **)(iVar16 + -0x3098), sVar20 == 0)) {
    local_34 = 0xff;
    else if (sVar20 == 1) {
    local_34 = 0;
    else {
    local_34 = (undefined)**(undefined2 **)(iVar16 + -0x30a8);
    DAT_600722ae = local_34;
    local_28 = 0x614;
    local_2c = 8;
    local_33 = DAT_600722af;
    local_32 = DAT_600722b0;
    local_30 = DAT_600722b2;
    local_2f = DAT_600722b3;
    FUN_0006a4d0(DAT_003364e2,&local_34);
    return 1;
  3. #13
    Nov 2019
    big difference there
  4. #14
    Nov 2019
    Entirely unrelated but I’ve figured out how to get the bootloader code from the ecm
  1. 2018 CME Exhaust brake memory .cax
    By DaneF in forum Cummins 6.7L
    Last Post: December 24th, 2023, 04:53 PM
  2. LML Exhaust brake memory
    By DaneF in forum Duramax 2011+ LML / LGH
    Last Post: May 10th, 2022, 06:17 AM
  3. CAX and CMD, CME
    By Red66 in forum Cummins 6.7L
    Last Post: July 13th, 2017, 05:53 AM
  4. LML Exhaust Brake Problem - I think
    By 2013 Silverado 3500 in forum Diesel
    Last Post: October 10th, 2013, 12:43 PM
