Results 1 to 4 of 4
Thread: Ls1 12225074 4l60 to 4l80 conversion
    May 2008
    Default Ls1 12225074 4l60 to 4l80 conversion
    Hi all, in the ,middle of a trans swap for my shop silverado LS1 turbo, from 4l60 to 4l80. the truck has been run for years with the tune but keeps eating transmissions so i have changed harness to 4l80 and fitted 4l80 trans but cannot find a 4l80 file to do a segment swap on. worst case i guess i will have to hand edit every table across to another file . but im stuggling to find a 12225074 4l80 stock file
    anyone have a ls1 4l80 base file i can swap injector data, ve tables etc across to ?
    What is that OS from?
    Al
    May 2008
    its a holden australian OS . at this point im happy to just get a 4l80 5.7 base file and modify it. unfortunately efi live wont let you swap tables from different OS so will be a whole lot of cut and paste but it what it is.
    If you don't have any other issues because of an OS swap, you might want to try an OS from the states that has both the 4L60-e and 4L80-e segments available.
    Al
  1. 4L60 to 4L80 2002 Silverado 5.3 DBW 12212156
    By markemac in forum Conversions / Aftermarket Parts
    Last Post: November 22nd, 2022, 04:42 AM
  2. engine wont start on 4l80 tune, runs on 4l60
    By BagD72Chevy in forum Gen III V8 Specific
    Last Post: June 2nd, 2016, 10:49 AM
  3. 4L80 conversion on 6L80 vechile, no speedo
    By Mike@sic in forum E37, E38 & E67 PFI ECM's
    Last Post: July 24th, 2013, 12:42 AM
  4. 4l60-4l80 transmission setting changes needed?
    By 05gmcsierra in forum Gen III V8 Specific
    Last Post: September 10th, 2012, 02:14 PM
  5. 2009 Silverado 4.3l/4l60 to a 6.2/4l80 engine/trans swap = ABS lite
    By mowton in forum Conversions / Aftermarket Parts
    Last Post: May 13th, 2012, 04:38 AM
