Results 1 to 3 of 3
Thread: p0342,0343 hard starting when codes cleared runs fine with cam sensor unplugged
    May 2008
    Default p0342,0343 hard starting when codes cleared runs fine with cam sensor unplugged
    Hi gang ,
    Have a customer car come in (stock LS1 auto(with a P0342 and P0343 dtc
    replaced cam sensor , still have the same error . Wierd thing is if clear the code the car will not start and sounds like its out of sync . if i disconnect cam sensor it starts instantly. if i log the cam hi/lo it is most definately seeing the cam sensor working. its like something is out of sync. the car is stock and as far as i know has just started throwing this code. its wierd that the codes seem to have a no signal for 5 seconds as the DTC trip but i can see the cam sensor working .
    open to ideas before i dive down into the mechanical rabit hole
    thanks
    May 2008
    finally got to the bottom of this after hours of diagnosis, the NEW cam sensor has the wrong damn polarity, thats why it was scanning as working but raising havoc on startup. Hope this helps someone else in the future.
    Quote Originally Posted by shane View Post
    Do you have a brand and part number of the sensor in question?
  1. 2016 Lml Runs right after starting twice.
    By DieselDan66 in forum Duramax 2011+ LML / LGH
    Last Post: December 21st, 2018, 09:34 AM
  2. Hard Start, Thinking Cam Sensor, Logs Attached
    By BigCE in forum Gen III V8 Specific
    Last Post: March 12th, 2016, 09:20 AM
  3. Fuel Pump won't work.. but car runs fine with relay bridged?
    By auspeed in forum Conversions / Aftermarket Parts
    Last Post: February 16th, 2015, 12:03 PM
  4. Replies: 1
    Last Post: February 2nd, 2012, 10:58 AM
