Thread: 2011 LML Cruise Control
    Mar 2022
    Default 2011 LML Cruise Control
    Recently tuned a "lightweight" LML, and lost cruise control afterward. The truck had an H&S programmer previously, and cruise worked with it. These are the file segments:
    Segment Description Part# Checksum Comments
    Boot Software 12646251 $60F19343
    Secondary Operating System 12646250 $4FE0608C
    Main Operating System 12646249 $1167F5E0
    Engine 12655862 $5B04914D
    Speedometer 12646363 $373AA8B5
    System 12655886 $CBF1C486
    Fuel System 12646324 $EB6F405E
    Engine Diagnostic 12655870 $3509C5C4
    Engine Operation 12655864 $B1AE0F45
    I've tried various combinations under Vehicle Options > Parameters, but no luck so far.
    Can anyone help me out here? I can send the tune in private message, but I prefer not to post it.
    Sep 2013
    I had this same thing happen on OS 12649244. I had to fiddle with the CAN communications to get it to work.
    It ended up being one of the "BLOx" sensors. Turned communication back on, and the cruise started working again.
    Mar 2022
    Thanks. I'll try that.
    Mar 2022
    Finally got to work on the truck again. Ended up being some speed limiters I set wrong. I believe B0603 is for cruise control, if I'm not mistaken. This is how I ended up setting the table
Name:	Screenshot 2024-04-12 221610.png
    Aug 2021
    Quote Originally Posted by Omega_5 View Post
    im having problems with it working but turns off by itself in diffrent time intervalls.
    you know exactly what Nox sensor CAN table to re activate?
    Sep 2013
    It's best to leave them all enabled, unless you're getting dash messages.
  1. 2011 cab and chassis. No cruise control
    By Sass5150 in forum Cummins 6.7L
    Last Post: May 9th, 2023, 04:12 AM
  2. 2011 lml 2500 W/T - No Cruise from Factory
    By wheresbrent in forum Duramax 2011+ LML / LGH
    Last Post: February 2nd, 2021, 03:25 PM
  3. ABS, Traction control, Cruise control..
    By GMCAMARO in forum Gen III V8 Specific
    Last Post: January 23rd, 2016, 03:10 PM
  4. LML Cruise control intermittant after flashing
    By shane in forum Duramax 2011+ LML / LGH
    Last Post: December 22nd, 2015, 04:15 AM
  5. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
