Results 1 to 10 of 11
Thread: How to scan speeds faster than 158 mi/h (255km/h)?
    Member Treurentner's Avatar
    Nov 2005
    Default How to scan speeds faster than 158 mi/h (255km/h)?
    Hi,
    if I use the SAE VSS pid it works fine until the limites are reached.
    If I try to rescale it in EFIlive it has the new max level but still stops at the limit, What causes this? Is it an SAE hardware limit? Can it be changed?
    I can calculate the "real Speed" by using a correction factor to the RPM pid in last gear but this should be only a band aid.
    At the Autobahn here in Germany I tried to do a topspeed run with our supercharged Corvette C5 and was hoping to see 200+ mi/h (320+ km/h) and so it would be really useful !
    Anyone else already noticed this problem?
    many thanks & best regards from Germany
    Marco
    Right click on SAE.VSS and go More Info...
    Quote Originally Posted by ScanTool->PIDs->SAE.VSS->More Info
    Vehicle Speed Sensor {SAE.VSS}
    Units: kmh
    Range: 0..255 kmh
    Units: mph
    Range: 0..160 mph
    VSS displays the vehicle's road speed if utilized by the control module strategy. Vehicle speed may be derived from a vehicle speed sensor, calculated by the PCM using other speed sensors, or obtained from the vehicle's serial data communications bus.
    Reprinted with permission from SAE HS 3000/2003 © 2003 SAE International.
    This pid is 1 byte in length, so it appears that 255 (all 8 bits of the unsigned byte are 1) is the maximum value in km/h (and this converts to 160 MPH).
    Jun 2005
    Quote Originally Posted by Treurentner
    Hi,
    Marco
    Yep got the same thing here, Marco.
    Joecar , Thanks for the heads up .
    Roy 98SSSSSS
    Can you get by the max limit by creating a calculated PID using the transmission output shaft speed. I have done this to verify the speedometer accuracy and improve speed resolution.
    Quote Originally Posted by blandmiller
    Yes, that should work, create a calculate pid to give you road speed from TOS, which you already did.
    The calc pid would calculate this:
    road_speed[mph] = (tos[rpm] * tire_diameter[inch]) / (gear_ratio * 336)
    Sep 2013
    What is the "336"? Is this the gear ratio or a multiplier used on the "gear_ratio"? (so if my rear end gear ratio is 3.25, would I use 325?)
    Or, if I'm interpreting correctly from previous posts, the "gear_ratio" is the currently selected gear's ratio, and the 336 is the differential gear ratio. Does a separate PID need to be created for "gear_ratio"?
    Quote Originally Posted by Blue70SS View Post
    Hi Blue70SS,
    The 336 is simply the constant of conversion from mph to rpm and inches (and/or vice-versa); it is not related to rear axle ratio.
    so for example (using say 6th gear):
    TR6060 6th = 0.63
    your rear axle = 3.25
    using engine RPM:
    gear_ratio = 3.25 * 0.63 = 2.0475
    road_speed[mph] = (engine_speed[rpm] * tire_diameter[inch]) / (2.0475 * 336)
    using have transmission output rpm:
    road_speed[mph] = (trans_output_speed[rpm] * tire_diameter[inch]) / (3.25 * 336)
    I don't know if there's a pid for the M6 trans output speed in RPM.
    May 2010
    Sorry to pull back old thread
    Joe What tos speed stands for ?
    for the gear ratio do you mean the rear end ratio or the selected gear ratio ?
    EFILive Tuner
    Jan 2009
    Trans output shaft.
    TOS = trans output speed
    gear ratio = trans current gear ratio x rear axle ratio
    edit: correction: if you're using TOS then gear_ratio is simply just the rear axle ratio.
  1. Faster Free Rev?
    By Wasted Income in forum Gen III V8 Specific
    Last Post: April 26th, 2010, 12:51 PM
  2. Long Tubes make GTO stumble at low speeds?
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2008, 02:42 AM
  3. Individual wheel speeds
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 12:30 AM
  4. Flashscan speeds?
    By halfmoon in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2004, 01:07 PM
