Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: How to scan speeds faster than 158 mi/h (255km/h)?
    Quote Originally Posted by Blue70SS View Post
    What is the "336"? Is this the gear ratio or a multiplier used on the "gear_ratio"? (so if my rear end gear ratio is 3.25, would I use 325?)
    Or, if I'm interpreting correctly from previous posts, the "gear_ratio" is the currently selected gear's ratio, and the 336 is the differential gear ratio. Does a separate PID need to be created for "gear_ratio"?
    Hi Blue70SS,
    The 336 is simply the constant of conversion from mph to rpm and inches (and/or vice-versa); it is not related to rear axle ratio.
    so for example (using say 6th gear):
    TR6060 6th = 0.63
    your rear axle = 3.25
    using engine RPM:
    gear_ratio = 3.25 * 0.63 = 2.0475
    road_speed[mph] = (engine_speed[rpm] * tire_diameter[inch]) / (2.0475 * 336)
    using have transmission output rpm:
    road_speed[mph] = (trans_output_speed[rpm] * tire_diameter[inch]) / (3.25 * 336)
    I don't know if there's a pid for the M6 trans output speed in RPM.
  1. Faster Free Rev?
    By Wasted Income in forum Gen III V8 Specific
    Last Post: April 26th, 2010, 01:51 PM
  2. Long Tubes make GTO stumble at low speeds?
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2008, 03:42 AM
  3. Individual wheel speeds
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 01:30 AM
  4. Flashscan speeds?
    By halfmoon in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2004, 02:07 PM
