Results 1 to 10 of 14
Thread: Question about A4 trans temp sensor for LS1 F-body
    Feb 2006
    Default Question about A4 trans temp sensor for LS1 F-body
    Today I was using the scantool to monitor my trans temp and compare the reading to my aftermarket guage. My sending unit for the after market guage is in the daig port on the side. While crusing today on the freeway @ 65-70MPH with the verter locked guage was reading about 165-170. Scantool was reporting 190+. What part of the tranny is the stock sensor pulling the temp from?
    EFILive newbie
    1999 Camaro SS A4 | LME Forged 347 | Yank SS4000 Stall | 226/234 Cam | Patriot LS6 Style heads 2.055 / 1.57 57cc 11.3 SCR | FLP Long tube headers
    Stock sensor is in the pressure switch module which is at the bottom of the valve body, so it's measuring the fluid temp near the bottom of the pan, physically between filter and valve body.
    Feb 2006
    Why such a big diffrence in the two. Which one should I believe?
    EFILive newbie
    I don't know....
    The fluid is sucked from the pan bottom, thru the filter, into the pump, and then on to the pressure regulator, and into the line pressure passage;
    the pressure tap on the side of the case is on the line pressure passage;
    I would have thought the pump would have heated up the fluid;
    this means one (or both) of the sensors must be wrong...
    if you have a handheld laser temperature gun (Sears, $100 or so), you could point it at the pan when it's hot and see what it says, see which sensor is the closest (the temp gun accuracy is calibratated to 1 or 2 degrees).
    Feb 2006
    Intresting... Isn't the fluid in the pan just retunred from the cooler?
    BTW: Guage is an Autometer short sweep electric.
    EFILive newbie
    Quote Originally Posted by Joel_SS
    No. The cooler return feeds the lube circuit (which lubes the planetaries, the bearings, and the rear of the the trans.).
    The pan is filled by the following:
    a. lube exiting from the planetaries and bearings (this fluid has gotten hot doing it's lube function);
    b. valves/solenoids exhaust/exit fluid.
    Edit : I'll see if I can dig up some diagrams.
    Could the action of sucking fluid thru the pump cool the fluid...?
    That can't cause a 25 degree temp drop, I don't think it can.
    Feb 2006
    http://members.cox.net/crashed/efi/39.jpgJoel did you say the aftermarket sensor is in the line pressure tap on the drivers side? If so there is minimal fluid flow there. If the pic I posted comes up you can see that #39 the plug only has one way pressure to it. There is no flow past it. I would believe the factory sensor.
    Quote Originally Posted by ChipsByAl
    Al,
    Good comment, I agree with that ... pressure but no flow at the tap;
    the main passage flows, but the branch to the tap is static (otherwise fluid would come out of the tap, but the tap is plugged by your gauge sensor); so temp at the tap is temp of static fluid in tap branch.
    Here's another diagram showing the tap (see # 39 on lower left):
  1. Logging Resistance Based Values - IE Oil Temp Sensor
    By Jasondt2001 in forum External A/D inputs
    Last Post: June 21st, 2009, 11:20 AM
  2. 2008 GMC Sierra trans question
    By Spindoctor in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 5th, 2009, 07:26 AM
  3. Trans swap - GenIV pcm T42 question
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 24th, 2008, 06:36 PM
  4. Question about A4 trans temp sensor for LS1 F-body
    By Joel_SS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 24th, 2006, 05:18 AM
  5. Swapping motor and trans, question about file & custom O/S
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2006, 09:14 AM
