Results 1 to 7 of 7
Thread: 1998 Road Runner?
    Feb 2006
    Default 1998 Road Runner?
    I read on another forum, that the 98's can be supported with a road runner device (but Craig does not have cores at this time)
    Does EFI live support the 98 OS's yet with roadrunner? I tried to write a 98 OS to my 99+ roadrunner, and got an error.
    Another quesiton, since I already purchased one license for my 99+ roadrunner, do I need to purchase another one, if I purchase a 98 road runner? Or does the no charge apply to the 98 road runner, like the unlimited flashing for 98 cars (can't hurt to ask )
    Jan 2004
    Quote Originally Posted by 1998ws6
    I read on another forum, that the 98's can be supported with a road runner device (but Criag does not have cores at this time)
    The reason you couldn't flash your 98 file into the 99 RR was due to it being a different PCM.
    I don't know the answer to the licensing question but will try and get you an answer.
    The 99-02 512k LS1 Roadrunner box will not work with the 98s.
    If you need a Roadrunner for 98s, it will need to be installed into a 98 PCM. And this would be a separate and additional Roadrunner. So you'd need to buy an additional $199 license for the new Roadrunner. One license per Roadrunner unit.
    Hope this helps.
    -Craig
    Jan 2004
    Quote Originally Posted by Craig Moates
    Hope this helps.
    -Craig
    Thanks Criag.
    Hope this helps.
    -Craig
    In addition, the unlimited 98 reflashing still applies. You can use your 98 RoadRunner to dial in a tune for a particular vehicle, then you can reflash the vehicle's original PCM with the tune from the RoadRunner. You can do that to as many 98 PCMs as you wish with no additional PCM licenses required.
    Feb 2006
    Thanks for the info.
    My core pcm should be here soon, and I will get getting in touch with you Craig shortly for the conversion.
    Ryan
    Lifetime Member Doc's Avatar
    Oct 2005
    How about an adapter and cut and paste the 98 particulars after you are done with the 99+up RR? Sorry Craig, I don't mean to deflate the 98 RR efforts I have been working on this for some time now. Actually, I would be interested in upgrading my orignal 98 core at some point too. How are things going with the 98 RR line?
Name:	98 to 99+up adapter4.jpg
ID:	861   Click image for larger version.
Name:	98 to 99+up adapter 2.1.jpg
ID:	862   Click image for larger version.
Name:	98 to 99+up adpater 3.JPG
    www.efialchemy.com
    www.greatamericancarwar.com
  1. Road Runner is frustrating me
    By billyjo in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 2nd, 2007, 04:46 AM
  2. Need help with Road Runner ASAP
    By esco35m in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 31st, 2007, 05:41 PM
  3. Can't connect to Road Runner
    By BlownAlaskan in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 03:46 AM
  4. Road Runner DEAD????
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 13th, 2006, 04:12 PM
