When do you or have you upgraded the stock fuel pump on these cars? The one I just bought has a H/C package pushing 430rwhp and I have a feeling I'm coming close to reaching its limits.
You are getting close.
I highly recommend this set up for higher HP cars.
http://www.ls2.com/forums/showthread...hreadid=427011
Elmer
2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
BTW, I was running a Walbro 255 on the car before I went to that setup. The boostapump that I had was useless.
stock pump is good for 450-460.
Put in a walbro 255lph with a hotwire kit and it is good for about 600 with stock lines. (i've seen cars push more, but this is a conservative number)
install a bulkhead fitting into the top of the fuel pump assembly, replace the factory feed line with -10, and use an aftermarket regulator, and the setup will support over 700.
2001 Arctic White Pontiac Firebird Formula M6
LME 408, AFR small bore 225s, TSP 248/254 .622/.612 114+2 cam, FAST 90mm intake/NW 90mm TB, TR 1 3/4" headers, SLP Dual/Dual catback, Spec 3i clutch, 3.73 Motive Gears, EFILive Custom OS 5
absolutely unnecessary to go with -10 line... I have seen cars push well beyond 70rwhp with just -6AN...
I see no reason to go over -8 ever.
I have the racetronix PnP fuel pump and wiring. I get a 10psi drop on WOT. Not sure what my problem is yet.
I've seen trucks make over 1k rwhp on 2 walbro intanks and stock lines and fuel rails
I have a customer with a 383, Blower and spray. All it had was twin fuel pumps and hot wired. Car made over 700hp on a mustang dyno. Monitored fuel pressure the entire time and all was great. I personally only have a intank (hotwired) as well as a inline pump (hotwired) and my FP never drops below 57psi.
in my car i have twin in tank setup... i copied the setup from LJ
para.noid.org/~lj
thanks for all the input! just wanted to make sure i'm not living beyond the edge...
