Results 1 to 10 of 11
Thread: Pulling timing
    Jan 2006
    Default Pulling timing
    After the CNC work on my heads my car is flowing a lot more so I started to re-tune it. Im losing 5 deg of timing at wot when before I wasnt. I am hitting alot of new cells now because of the more air but still, Im loosing timing at 5500rpm and .88g/cyl. What could be pulling timing, I found 2 deg from IAt but cant find the other 3.
    Jan 2006
    I have checked all the most common causes.
    Oct 2005
    Aspark? Bkr?
    2014 VF SV LS3 Maloo.
    Jan 2006
    0 kr
    Member VYSSLS1's Avatar
    Dec 2005
    monitor - burst knock retard
    Jan 2006
    Quote Originally Posted by VYSSLS1
    Thanks alot... thats what it was. I played with it for a couple of hours and ended up zeroing it out. With BK baically turned off from 3600rpm on up I get 0.0 deg of KR and my wot timing is now what it should be. Can I leave it like this or is it hurting anything? I have 26 deg at wot at .96 grams/cyl. I never had an issue till I had the heads worked and started seeing more grams/cyl.
    Dec 2005
    Quote Originally Posted by minytrker
    ah no worries as long as its all ok, yeah the first time i cam across this exact prob you had, it had me stumped for a little bit as well.
    VYSS,
    Welcome to the forum mate (I should have picked up on this in the other thread).
    Sep 2003
    B KR is preemptive if the PCM sees large changes of air (especially spikes in the VE table when in SD mode ) it will pull timing before it actually happened
    Larry - HumpinSS
    Dec 2005
    VYSS,
    Joecar, im not new to the forum been here a little while now
    anyway ill take this opertunity to say hi to all on here.
    Cheers Brad.
  1. Car is pulling timing
    Last Post: February 27th, 2010, 04:55 AM
  2. Pulling timing for nitrous
    By SRT10KLLR in forum Gen IV V8 Specific
    Last Post: November 13th, 2009, 04:52 AM
  3. Pulling Timing - No idea why
    By Camaro SS in forum Custom Operating Systems
    Last Post: May 12th, 2009, 02:50 PM
  4. pulling timing not in program
    By 496chevy in forum Custom Operating Systems
    Last Post: November 9th, 2008, 03:03 PM
  5. Pulling vaccum at WOT
    By cmitchell17 in forum Gen III V8 Specific
    Last Post: September 30th, 2007, 02:55 PM
