Hopefully I am not missing something basic here - I currently have the roadrunner powered by the USB port sitting on my workdesk and am trying to get it setup for installation.
What I would like to do is read the currently emulated image from the pcm. Whenever I select "Read Operating System and Calibrations from RoadRunner pcm" it seems like I get the OE flash image on the pcm"
Case in point:
1) Fresh roadrunner - click "Read Operating.." - I get an f-body calibration, OS 12202088
2) I have an '00 vette, want to upgrade to a '02 V5 OS. I have the V5 OS .tun file as well as a stock OS tun file from the same OS(12212156).
3) I open the custom os file (02020005) and click program OS and calibration data. This seems to work.
4) I then open the stock file with OS 12212156 and click program calibration data - this works as well.
5) I click "Read Operating System..." - I still get the same f-body calibration OS 12202088.
6) If I click "Program Calibration..." (not OS & Cal) then I get the error "The *.tun file's operating system number: 12202088, is not compatible with the RoadRunner's operating system number: 02020005. ..."
So it seems the correct image is downloading and stored in emulation, but I can not discover how to copy it back out. Since I am going to a custom OS I understand I need to do this to create a complete .tun file that represents my baseline (and I would like to do this to verify what is in emulation).
I followed the install instructions at:
http://www.moates.net/roadrunner/livestart.htm
with the caveat that I started with the current efilive version from the website (build 467).
When I copied over their referenced EFI Live Roadrunner executables (http://www.moates.net/zips/efilive/E...61_520_430.zip) it reverted me to build 430.
After the issues I tried doing a repair install and this time not copying over the 430 executables (though I did copy over the .cal files - http://www.moates.net/zips/efilive/e...s_20060303.zip ). EFI Live now indicated build 467 but I still had the same issues.
(I did copy across the appropriate cal's for 02020005).
Not sure at this point if
1) I'm missing something blindingly obvious
2) It's a RoadRunner Bug
3) It's and EFILive bug
I contacted thunder, who couldn't help me (appropriate people were out today) but directed me to Craig. Still waiting to hear back (it is Saturday after all ) - but hoping someone here may have some notion of what my problem is.
