Results 1 to 5 of 5
Thread: Viewing 2-d data
    Feb 2005
    Default Viewing 2-d data
    How can we view 2-d data such as maf freq. vs maf airflow?
    Sep 2003
    Just set one column to rpm 8000 and that should take care of it
    Feb 2005
    Quote Originally Posted by Dirk Diggler
    I am not logging any data at 8000rpm. Can you explain why this should work?
    99 FRC 402 Twin Turbo
    Each column logs data for all data points that fall within the range of values that are greater than the previous column label and less than or equal to the current column label.
    The first is different because there is no "previous" column. It will contain all values less than or equal to the column label.
    Feb 2005
    Ok,
    thanks.
    I also see that we can export the data we want to a csv file. Totally cool.
  1. Idle Tuning w/ Pics for your viewing pleasure
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 22nd, 2009, 02:31 AM
  2. Log data freeze
    By Rusty in forum Gen III V8 Specific
    Last Post: January 20th, 2009, 08:40 AM
  3. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 05:04 PM
  4. Tuning without IAT Data
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 01:14 PM
  5. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
