Results 1 to 4 of 4
Thread: 02 Vette Twin Turbo
    Jul 2005
    Default 02 Vette Twin Turbo
    Tuning Custom OS and came was comparing a tune from a shop in AZ to a stock tune. The Base Spark in Gear tables in the two tunes are WAY DIFFERENT. Should they be or should I install the stock Base Spark in Gear and go from there?
    Is all the timing being pulled out of the turbo tune to eliminate KR? Any ideas?
    Give me an e-mail and I will send the two tune filesl
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Jun 2005
    You should not have to pull any out untill you are flowing more air. Idle should be close to the same. You canno tuse a tune on another car. You will have to log spark and see where it is going on the map to know what cells to reduce timing in under WOT.
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Jul 2005
    The turbo tune is from my car. I was just doing some comparisions with a stock tune and notice how different these tables were in the two tunes. Do you think this is probably normal with only 7psi from the turbos?
    thanks
    Lonnie
    2002 EB Coupe, MN6
    Jun 2005
    I'll tell you what. If you send me a list of your mods, and your turbo setup along with your tune and a log under full boost, I will put a "tweak" on it for you. SD tune??
    scotmich@wi.rr.com
    Do you plan on more boost?? The timing table should be almost the same as stock right now.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
  1. TPS 20% only after installing APS twin turbo
    By ALRAJHI in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2007, 12:27 PM
  2. twin turbo's
    By limited cv8r in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 15th, 2007, 03:22 AM
  3. 2003 Vette twin turbo done with OS3
    By Alvin in forum Custom Operating Systems
    Last Post: February 22nd, 2007, 09:27 PM
  4. STS Twin Turbo
    By purrvert in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 20th, 2006, 09:25 AM
  5. Pic of my Twin turbo Chevelle you asked about.
    Last Post: October 11th, 2005, 11:11 AM
