Results 1 to 5 of 5
Thread: Setting A Startup Dashboard?
    Senior Member VortechC5's Avatar
    Jun 2003
    Default Setting A Startup Dashboard?
    Is there a way to change the default dashboard permanently?
    I have been working on a new dash layout (a hybrid of the default dash pages and what Whitney Roberts made available). I find that I have to reload it every time that I fire up EFILive. I looked in options but did not see a way to set the dashboard so that EFILive starts/initializes with the dashboard that I want it to.
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
    Feb 2004
    Unless V7 changed things, the dashboard you are using at the time you log is the one that will come up for that log. So everything you log with the new dash should open with that dash automatically. The old logs will have to be opened and then change to the new dash everytime.
    I hope I am wrong, though.
    Jun 2003
    Ok that explains it. I have not logged any data with the new dash yet. I had never used any custom dashboards so I did not know of that relationship.
    It would still be nice if I could make whatever dash I want be the default whenever I open EFILive.
    Quote Originally Posted by VortechC5
    This has also been requested by one of our beta testers, and an option to allow a default dashboard to be configured is "in the works".
    Jun 2003
    Great! Thanks for adding this to the enhancement list.
  1. how to control startup RPM
    By acric5 in forum Gen III V8 Specific
    Last Post: July 19th, 2009, 02:22 AM
  2. Question about Startup A/F
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: December 10th, 2008, 07:55 AM
  3. Help with startup....
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: December 14th, 2007, 11:31 AM
  4. LS2/7 ETC TB startup
    Last Post: December 14th, 2007, 01:39 AM
  5. Startup Airflow and Startup Friction Airflow whats the difference
    By carneb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 08:59 AM
