looking at my tables today and noticed under the performance table on the base pressure they seem to be set at a constant 620 Kpa and the regular table increases as engine torque increases. I would like to get rid of the addaptive learning and figure out what would be a good pressure to set it at ? I was thinking of setting the regular table the same as the performance table as it would hold the clutches better and posibly prolong the life of the trans but at the same time im unsure of what exactly these tables are changing as I simply want to increase line pressure in the transmission.
thanks
