Results 1 to 10 of 13
Thread: KR during rich condition???
    Jun 2006
    Default KR during rich condition???
    OK, back to square one ... re-did my initial AutoVE setup, 15% added to VE-tables, commanded AFR looks a lot better under WOT ... got the first 40min run down for correcting the VE tables, but where is this knock coming from? With AFR values in the 11 and 12 range, and rather low RPMs, what could be causing this? Bad timing?
    Jun 2006
    P.S. - in order to get more info on the KR situation, I checked the available maps ... one plots the KR against the CYLAIR value, which is a calculated PID against MAF ... can I instead use one of the DMA-CYLAIR PIDs, as I don't have the MAF connected during AutoVE ... I suppose they won't work then, either ... guess I could re-connect the MAF for a KR testrun ...
    Aug 2005
    Looks to me like you've got too much timing for such high load at low rpm...
    Aug 2005
    Quote Originally Posted by Garry
    Use GM.CYLAIR_DMA or GM.DYNCYLAIR_DMA (they should read the same in speed density), and alter your map to display using that as your column data field instead of CYLAIR.
    Justin
    Jun 2006
    OK, will do ... (with or w/o MAF re-connected?)
    Jun 2006
    Quote Originally Posted by dc_justin
    Driving on a normal road, it's more or less the only way to get the high MAP cells filled ... low speed, high gear, pedal to the metal ...
    Aug 2005
    It's still too much timing there. I'd be surprised if you can't hear the pinging (and definitely can feel it). My 02 had similar KR with the stock timing table. Pulled the timing out of the lug-zones there and it runs a lot better... although I prefer not to drive in those high-load, low-rpm ranges.
    What mods have you done to your powertrain ?
    As for the PID suggestions, CYLAIR_DMA is the one to go with, MAF or MAFLess, as it is what the PCM uses for computations. As per the scan tool PID description, DYNCYLAIR_DMA is the speed density airmass. This can be confirmed by logging both CYLAIR_DMA and DYNCYLAIR_DMA and comparing your results while in speed density vs mass-air.
    Jun 2006
    It's not exactly my normal driving style, either ...
    Nothing yet ... may get some stuff done through the winter, though ...
    OK, so I'll leave the MAF out and just logg both CYLAIR PIDs, see what I get out of that ...
    Tnx
    Lifetime Member Scoota's Avatar
    Mar 2005
    Garry, It looks to be Burst Knock Retard you are experiencing there.
    Cheers Scotty
    It's a lot easier to ask for forgiveness than it is to ask for permission.
    Jun 2006
    I will be loggin the DMA DYNAIR PIDs on the way home, from what I read here on the forum that may/should give some insight whether it's real knock or BKR ... !?
  1. Hard start condition with 5.7 in 2000 S-10
    By lowriders10 in forum Vortec V6/V8 Specific
    Last Post: May 30th, 2010, 03:56 PM
  2. '01 Reading flash causes no-start condition
    By mike_s in forum Duramax LB7
    Last Post: April 16th, 2010, 07:51 AM
  3. What condition would this cause?
    By samh_08 in forum Gen III V8 Specific
    Last Post: March 16th, 2010, 05:28 PM
  4. too rich?
    By eclispe1 in forum Custom Operating Systems
    Last Post: March 10th, 2009, 04:57 PM
  5. WOT afr too rich
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2005, 06:08 PM
