Hi,
working with the PIDs in the Scan tool I have two pet peeves which might make a nice improvement in the next release ...
One, when calculated PIDs are not available, I know I can get additional infos which will show which physical PIDs are required for a calculated PID to be valid - it would be nice if Scan had a menu option (right mouse button) to automatically select the PIDs used by a calc-PID.
Also, a search function would be cool Currently, the easiest way to find some PID you don't know what it's called is to select all, copy the contents into an editor, and search there
