Results 1 to 2 of 2
Thread: USB drivers
    Jan 2006
    Default USB drivers
    Having used 7.3.1, I upgraded to 732, but have not done the driver upgrade.
    I have used the cable to log. So I am confused
    What do I need the new drivers for?
    Custom Tuning Services
    If another application is installed on your computer that uses the newer driver then the newer driver may partially overwrite the old driver causing the old driver to stop working. If the old ones work fine then there is no real need to upgrade.
  1. USB drivers Pop-up
    By white01ss in forum FlashScan V2
    Last Post: June 5th, 2008, 04:40 AM
  2. V1 and V2 same USB drivers?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: March 27th, 2007, 06:51 AM
  3. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
