1. You should be able to change the vin using the Scan Tool (goto Bidirectional->Change VIN).Originally Posted by 350SS
2. Each PCM that you flash requires its own license based on PCM serial number (except 97/98) regardless of VIN/vehicle;
if not already allocated, a license is allocated when you flash a particular PCM for the first time (goto Help->FlashScan PCM Licensing).
3. PCM license is only required when flashing; for scanning/saving (and generally connecting to vehicle to scan or read the PCM) you may need the software registration key and cable serial number (goto Help->Register EFILive).
4. Don't know, need someone else's input here.
